Electric field calculation for 3 point charges
The discussion centers on calculating the electric field at the location of sphere B after it has been removed, with spheres A and C remaining. To determine the electric field at that point, the electrostatic forces exerted by spheres A and C are considered, treating sphere B as a test charge. The electric field is defined as the force experienced by a unit positive charge placed at that point, calculated using the formula E = FB/qB. The explanation clarifies that even though sphere B is removed, it serves as a reference for measuring the electric field created by the other charges. This understanding is crucial for solving similar electrostatic problems.
vf_one
Hi I'm having difficulty understanding why the solution for the answer to the following problem is worked out this way.
Three spheres are placed at fixed points along the x axis, whose positive direction points towards the right.
Sphere A is at x=47cm with a charge of 5x10-6C
Sphere B is at x=50cm wtih a charge of -5x10-6C
Sphere C is at x=54cm with a charge of 10x10-6C
Sphere B is removed. What would be the magnitude of the electric field at the point where sphere B was located?
I've managed to work out the electrostatic force on sphere B using F= kqAqB/r2 and F= kqBqC/r2.
In the answer it says that we use the equation E=FB/qB. I don't understand why we use the electrostatic force on sphere B and the charge of sphere B to work out the electric field since B is removed and only spheres A and C are left.
Can anyone explain this to me?
Thanks
Thanks
To figure out if there is an electric field at a point in space, in what direction it points and how strong it is, you need to bring a positive test charge of known value q at that point and measure the force on that charge. The magnitude of the force divided by the value of the test charge is (by definition) the magnitude of the electric field. The direction of the force is the direction of the electric field. So this question describes exactly this process with sphere B being the test charge.
We didn't go over this in class so this really helped. Thank you!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
