Electric Field Direction: Are We Assuming a Universal Positive Frame?
The discussion revolves around the conceptual understanding of electric field direction, particularly questioning the assumptions regarding a positively charged background and the implications of different environmental conditions on electric field lines. Participants explore the definitions and conventions surrounding electric fields, voltage, and potential gradients, with a focus on both theoretical and practical implications in various contexts, including non-linear environments like plasma.
  • Some participants suggest that the direction of electric field lines is based on the convention of a positive test charge and the definition of the electric field vector.
  • Others question the assumption of a neutral or positive surrounding, proposing that different environments could affect the definition of field lines.
  • There is a discussion about the relationship between voltage and electric field lines, with some arguing that field lines are not arbitrary and depend on the potential gradient.
  • Participants explore the implications of a negatively charged surrounding and whether the established definitions still hold true in such cases.
  • Some contributions highlight the complexity of electric fields in non-linear environments, such as plasma, and the challenges in determining the total electric field in these contexts.
  • Concerns are raised about the rapid changes in force vectors due to particle interactions in non-linear media, but some assert that the fundamental definitions of field lines remain applicable.
Participants express differing views on the assumptions underlying the direction of electric field lines and the influence of environmental conditions. There is no consensus on whether the definitions of field lines are universally applicable or if they vary based on the surrounding charge distribution.
Some participants note the importance of understanding the electric field vector and potential differences, while others highlight that the discussion may lack clarity regarding the definitions and assumptions involved in different contexts.
justacuriouskid
TL;DR
Do electric field directions assume a positively charged background? Just wondering if field lines are defined based on this assumption.
Hey! I'm a high school student trying to understand electric fields at a deeper, more conceptual level. I had a random thought I wanted to share to get your views on it.
So far, I've learnt that electric field lines of a positive charge run outward and that of a negative charge run inward.
But here's where I wondered:
Is this direction based on a positively charged background?
How can we assume a "Default" direction for a field line? What if the surroundings weren't always neutral or positive? Would that affect how we even define field lines?
Thanks in advance!
Welcome to PF.
Voltage is a potential difference. There must always be a zero reference voltage somewhere, often called ground.
It's based on a convention that test charge is positive, and definition of ##\vec{E}=\frac{\vec{F}}{q}##. For positive source it is outwards, and so are field lines, since their direction is the direction of electric field vector, per definition. It could be the other way around, if people agreed to use negative test charges.
Also I don't know what you mean by "charged background" since there is no background in the definition :smile:
EDIT: I wonder if electric field vector was defined at your school already, because it's crucial in all of this.
Baluncore said:
Welcome to PF.
Yeah. So if voltage is relative to a reference, why not electric field lines?
Yeah. So if voltage is relative to a reference, why can't electric field lines?
Because they point up or down the potential gradient, and which direction it's sloping is independent of where you call zero. The convention is around where you put the arrowhead - pointing towards more negative or more positive - but the direction of the lines is not arbitrary.
Why can't electric field lines what?
If not specified, it is probably assumed that there is a potential of zero, at a distance of infinity in all directions.
We are talking about field lines, or about voltage? I see no voltage in OP.
The failure of the OP to mention potential difference, or voltage, should not cripple the response.
The electric field lines flow down the potential gradient. The lines that radiate from a positive charge will end at a lower potential, they may converge again at a negative charge, or they might spread out to a zero potential ground.
So, like the direction of the electric field lines is defined as their direction in a neutrally or positively charged surrounding, right? In that case, when we consider a negatively charged surrounding, the definition doesn't always stand true, right?
Well, yes, but field lines are integral curves of electric field, and in non-static situations one does not have potential, so for me thinking in terms of E vector is kind of superior. But I know, it's high school level... Anyways, it all boils down to the fact that test charge is positive.
No, direction of electric field lines is the direction of the force that would act on a positive charge at the point you are considering.
What will happen to electric field lines in a nonlinear field?
No. The gradient from positive to ground, or to a negative environment, is still downhill. The downwards gradient, in volts per metre, will be steeper, in a more negative environment.
What do you mean by a non-linear field?
Let's just take a step back before you throw in new terms that probably don't mean what you think they mean.
When you talk about a "background", are you imagining something like a sea of electrons and one small region with slightly fewer electrons? So there is everywhere a negative charge but one small region is slightly less negative? And then you are asking about the field in this sea around this small region that is still negatively charged, just slightly less so than its surroundings?
Yeah, here is where I’m confused. We learnt that the direction of the electric field lines depends on the direction of the potential gradient. Now if I consider environment, which is not in vacuum or a neutral surroundings what will happen?
Consider space, an astrophysical environment where it’s filled with plasma, which is just a non-linear environment. What happens?
Not in any relevant sense, no. It's just a sea of positively and negatively charged particles. You can add the fields of each one together, either adding the potentials or adding the force vectors at each point. The field lines inside the plasma will run from positive charges to negative ones, and they'll be really messy and time dependent. That's all.
Yeah, but these force vectors change rapidly because of particle collisions, acceleration, etc., don't they?
They do, but the definitions and directions of field lines still work the same. Although, then scalara potential is not enough, and electric field depends on the magnetic vector potential also.
Ok, let me get this straight. I understand that the direction of field lines is gonna always be in the direction of the force. Now, my bigger question is, about the total electric field. So for linear systems, we find the total electric field as the vector sum of the electric fields of the involved charges. But in case of plasma, where force vectors change so quickly, is there a way by which we can actually determine the total electric field?
It's still the sum of electric fields. Non-linear medium does not mean that electrodynamics is not linear - Maxwell equations are always linear.
PS. Is that Ariana Grande in your avatar? 💀
  • · Replies 22 ·
  • · Replies 73 ·
  • · Replies 18 ·
