gracy
- Messages
- 2,486
- Reaction score
- 83
vector E.nasu said:What line originates from x axis?
Nothing originates from the x axis. The parallel lines are projections of the equipotential surfaces onto the (x,y) plane. They are not vectors. They extend farther, so they intersect the x axis. It is not shown as it would make the 3D figure too complicated.gracy said:We can see that the line(linear vector)originates from x axis.But origination can not be considered as intersection.Because intersection is like cutting the plane,right?It is my last question,promise.
But how would then calculation work?we should have same scenario that 30 degrees then AB etc,in order to do further calculations.ehild said:If you want the electric field at the origin, you draw it there.
Yes but it is for the given case but if we change the place of E,would not it hurt the calculations?ehild said:The calculation is written quite clearly in the book.
nasu said:Yeah, but in the original figure they show the right angles with markers. They were missing in the OP.
Of course, these angles are not really 90 degrees as drawn but they are shown to be so. A distorted figure is not really an error.:)
nasu said:The planes are not spaced by 10 cm, this is not what the figure shows.
nasu said:It's clear from the solution that he did not mean it to be distance between planes. He (author) calculates this distance as 5 cm.
