Electric field in electrostatic situation
The problem involves two positively charged particles, q1 and q2, separated by a distance s, and seeks to determine the distance from charge q1 at which the total electric field from both charges is zero.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem, including the placement of point P between the charges and the formulation of a quadratic equation based on the electric field equations. Questions arise regarding the elimination of one solution from the quadratic equation and the physical conditions that must be satisfied for the distance x.
Participants are actively exploring the implications of the quadratic solutions and the conditions under which the solutions are valid. There is a focus on determining which solutions are physically meaningful based on the positions of the charges and the constraints of the problem.
Participants note the importance of considering the relative magnitudes of the charges q1 and q2 when evaluating the solutions, as well as the requirement that the zero-field point must lie between the two charges.
Blehs
Two particles with positive charges q1 and q2 are separated by a distance s. Along the line connecting the two charges, at what distance from the charge q1 is the total electric field from the two charges zero?
E = kq/r2
where k = 1/(4 x pi x epsilon-nought)
Ok so basically the picture is something like this
q1-------P--------q2
|<---distance s-->|
Where I've placed the point P randomly in between charges q1 and q2. I've called the distance between q1 and p "x", and the distance between q2 and p "s-x"
So I've basically substituted q1 and x into the equation. Then i substituted q2 and (s-x) into the equation. Then i equated E1 and E2 to obtain a quadratic equation.
x2(q1-q2) - x2q1s + q1s2 = 0
Ive gone ahead and solved this for x using the quadratic formula. Since there were two answers cause of the plus minus, i just eliminated the minus part of it to get
x = [2q1s + root(4q1q2s2)] / 2(q1 - q2)
I canceled out the 2's on the top and the bottom. However when i input my answer its not correct. Maybe i made a mistake somewhere? I don't know i can't seem to find one for now.
I think yours is an algebraic problem:
why did you eliminated the solution with the minus?
Which are the physical conditions on x?
The entire question is posted above.
I forgot to add this in before, but i opened up a hint on "solving the quadratic and choosing the correct answer"
"If you set the magnitudes of the fields due to q1 and q2 equal at point P, you should end up with a quadratic equation for x. This equation will have two solutions, but since you know that the zero-field point must be between the two charges, you should be able to eliminate one of the results. Also if you assume that q1 is not equal to q2 then you can use the relation
a - b = (root[a] + root)(root[a] - root)
to simplify your answer."
Hope that helps a bit more
Yes,but how do you eliminate the extra solution? (I wanted you to answer this :D)
To choose the right x,you have to pose the condition you posted, that is the x must be between the two charges [itex]\Rightarrow 0\leq x\leq s[/itex]
So, you must solve this inequality
[itex]0\leq \frac{q_1\cdot s \pm s\sqrt{q_1\cdot q_2}}{q_1-q_2}\leq s[/itex]
First you put [itex]q_1>q_2[/itex] and solve, and then you put [itex]q_1<q_2[/itex] and solve.
Hope it helps...
Ok so when you say solve the inequality, I am guessing you mean try the conditions where q1>q2 and q1<q2 and see if the value still lies within zero and "s".
So first i started off with the - solution which is
s(q1 - root[q1q2]) / (q1 - q2)
For the q1 > q2 condition i found using logic that the value remained within zero and "s"
For the q1 < q2 condition i found that the value was actually larger than "s" so it didnt satisfy the requirement.
Then i did the same thing for the + solution
s(q1 + root[q1q2]) / (q1 - q2)
For the q1 > q2 condition i found that the value was larger than "s"
For the q1 < q2 condition i found that the value was a negative number
So according to all this, it means that the only solution that works is when q1 > q2 for the solution using the negative sign
Is this what you wanted me to do? Did i get it right? =P
AHA YES I GOT IT RIGHT WOOOOOOOOT
Thnx heaps DiracRules
  • · Replies 0 ·
  • · Replies 17 ·
