Electric Field in Gravitational Shockwave Geometry?
Physics Monkey
Hi all,
I'm interested in the behavior of electric fields in a gravitational shockwave geometry. I'm specifically thinking about gravitational shockwaves due to null shells as discussed, for example, in Dray-'tHooft http://www.sciencedirect.com/science/article/pii/0550321385905255 (available here as well http://dspace.library.uu.nl/handle/1874/4758).
The basic feature of these shockwave spacetimes is that the shockwave produces a shift in one the null coordinates as the shockwave is crossed. For example, if the shockwave is given by ## u=0 ## then across the shockwave ## v \rightarrow v + \delta v ##. See Fig. 1 in the Dray-'tHooft paper.
One can also find such solutions in systems with electric charge, e.g. a charged black hole (e.g. http://arxiv.org/abs/hep-th/9408169).
My questions are:
1. What does an electric field crossing such a shockwave "look like"? Is it also "carried along" the shockwave for a while? Here I'm trying to get a sense of the physics, e.g. if the horizon in Fig. 1 had one unit of charge one it (+1 on left horizon, -1 on right, no net charge), what would the field lines look like after the shockwave?
2. Is anyone aware of a treatment of boundary conditions of electric fields (or other types of matter) across such a shockwave? 9408169 makes no mention of any special boundary conditions as far as I can tell. The assumption seems to be that nothing singular happens except in the metric and everything else is glued smoothly.
Thanks!
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
