Electric field inside a dielectric sphere with cavity
The discussion centers on calculating the electric field inside a dielectric sphere with a spherical cavity, specifically addressing the implications of different permittivities for the materials involved. The original problem involves a nonconducting sphere with a uniform charge density and a cavity, raising questions about whether to use the dielectric constant of the sphere or the vacuum permittivity for the cavity. Clarifications are made regarding the treatment of an imaginary sphere with negative charge density and its material consistency with the surrounding sphere. Comparisons are drawn to a separate problem involving a toroid with different permeability materials, highlighting the differences in approach due to charge distribution. The conversation concludes with an acknowledgment of the complexities involved in these calculations.
Leotron
Original Problem:
"A sphere of radius a is made of a nonconducting material that has a uniform volume charge density [PLAIN]http://jkwiens.com/2007/10/24/answer-electric-field-of-a-nonconducting-sphere-with-a-spherical-cavity/d2606be4e0cd2c9a6179c8f2e3547a85_2.gif. A spherical cavity of radius b is removed from sphere which is a distance z from the center of the sphere. Assume that a > z + b. What is the electric field in the cavity?"
I understand how to solve an ordinary problem like this, but what if the sphere has dielectric constant ε which is different from the cavity whose permittivity is ε0? When solving this, should I treat the imaginary small sphere with -ρ to have permittivity ε or ε0?
The imaginary sphere has the same material as the sphere around it. Not sure if that influences the result at all.
Likes Jilang
But when I was doing another problem which deals with calculating the self inductance of a toroid with a small gap, whose permeability is μ for the iron part and μ0 for the gap, the answer uses μ0 to calculate the B field in the gap (used "imaginary wire loop")...And the answer is definitely different using ε/ε0 in the sphere case. Still not sure why. Maybe the answer of that problem is wrong...
For the toroid magnet, you don't remove something, you treat it as circle with two different materials the whole time. And you don't have a charge distribution as you have here.
Woo that makes sense...Thanks!
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
