Electric field of a cylindrical capacitor
The discussion focuses on calculating the electric field of a cylindrical capacitor consisting of a smaller inner cylinder with charge +Q and a larger outer cylinder with charge -Q. The solution involves using Gauss's law, defining a Gaussian surface that encloses the inner cylinder and lies within the outer cylinder. The derived electric field is expressed as E = Q/(2πrLε₀) for a cylindrical surface where the radius r is between the two conductors. A key point raised is the assumption that the length L of the cylinder is much greater than the radius b, similar to assumptions made in parallel plate capacitor analysis. This stipulation is crucial for ensuring the uniformity of the electric field between the capacitor plates.
Eigenvaluable
Calculate the electric field of a cylindrical capacitor comprised of a smaller cylindrical conductor of radius ##a## enclosed within a larger cylindrical conductor of radius ##b## where ##b>a##. The smaller cylinder has charge ##+Q## and the larger cylinder has charge ##-Q##.
$$\oint \vec{\mathbf{E}} \cdot \vec{\mathbf{dA}} = \frac{Q_{\text{enclosed}}}{\epsilon_0}$$
I've already solved the problem, as follows:
Define a Gaussian surface in which the cylinder completely encloses the smaller cylinder and is completely within the larger cylinder, i.e. a Gaussian cylinder with radius ##r## where ##a<r<b##.
Furthermore, let ##L## denote the length of the cylinder.
$$(2 \pi r L) E = \frac{Q_{\text{enclosed}}}{\epsilon_0}$$
$$E = \frac{Q}{2 \pi r L \epsilon_0}$$
While this is trivially easy, this reference sheet assumes that ##L >> b## prior to calculating anything.
Why must this be done?
Thank you,
Eigenvaluable
Hello Eigenvaluable, Welcome to PF.
A similar stipulation is made in the analysis of parallel plate capacitors where the plate dimensions are taken to be much larger than the plate separation. Consider the assumptions being made about the field between the capacitor plates. Do they hold true everywhere?
