Electric Field/Oscillation Problem
  • Thread starter Thread starter barnsworth
    Electric
The discussion revolves around a physics problem involving a charged bead sliding along a rod with fixed charges at each end. The electric field due to the charges is derived, showing that for small displacements, the field is proportional to the distance from the center. It is established that if the bead's charge is the same sign as the fixed charges, the force acting on it is directed towards the center and also proportional to the displacement. The participants struggle with finding the period of oscillation, attempting to apply concepts from simple harmonic motion but facing complications in their calculations. Clarifications on using Coulomb's law and the relationship between force and displacement are suggested to aid in solving the problem.
barnsworth
A small bead of mass m, carrying a charge q, is constrained to slide along a thin rod of length L. Charges Q are fixed at each end of the rod.
a) Obtain an expression for the electric field due to the charges Q as a function of x, where x is the distance from the midpoint of the rod. (Answer is kQ[(L/2+x)^-2 - (L/2-x)^-2]^I)
b) Show that for x << L, the magnitude of the field is proportional to x.
c) Show that if q is of the same sign as Q as, the force that acts on the object mass m is always directed toward the center of the rod and is proportional to x.
d) Find the period of the oscillation of the mass m if it is displaced by a small distance from the center of the rod and then released. (Answer is 2 * pi * sqrt(mL^3 /32kqQ) ).
So part (a) was pretty easy. I just did E = kQ/r^2 – kQ/r^2 and got the book answer.
The next three parts i don't know what to do. For part (d) i know that T = 2 pi * sqrt(m / k).
Then i did kx = qE to solve for "k" of spring, plugged in E, but it left me with some overly complicated equation.
Anyways, thanks for any help in advance.
For b), you got the equation so it will be pretty simple to explain that the magnitude is proportional of the E-field to x. For example, you can try and make x, 2 times larger, and see what happens. And remember that x << L.
c) Use coulomb's law and get the force.
d) Put all the forces together in one equation and solve for the period. Just like a normal Simple Harmonic Oscillation, I guess.
Thanks for the response, f -- but I'm still not quite sure not to do on (d).
I did:
Coulomb's law:
kQq/(1/2L+x)^2 - kQq/(1/2L-x)^2 = kx = ma.
a = kQq/m(1/2L+x)^2 - kQq/m(1/2L-x)^2.
2pi*f = sqrt(kQq/m(1/2L+x)^3 - kQq/m(1/2L-x)^3)
Which is definitely wrong... I guess it would help if i remembered exactly how to do SHM.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
