Electric field question help. Fairly simple but think I'm making small mistakes
KatherineK
The electric field at the point x=5.00 cm and y=0 points in the positive x direction with a magnitude of 10.0 N/C. At the point x=10.0 cm and y=0, the electric field points in the positive x direction with a magnitude of 15.0 N/C. Assuming the field is produced by a single point charge, find (a) it's location and (b) the sign and magnitude of its charge
E= kq/r^2
1.5E1=E2
1.5 kq / x^2 = kq/ (x-5)^2
1.5(x-5)^2 = x^2
used quadratic, got x=27.2 , assumed charge is positive because E field strength increases as you move in the positive x direction.
BUT I think my reasoning might be wrong..
Hi KatherineK, welcome to PF!:smile:
You might be confusing yourself with this notation; what does the "x" in this equation represent?
Are you assuming that the charge is located along the x-axis (y=0)? If so, what is your reasoning to support this assumption?
I was making x the distance the charge is from the first electric field (10 N /C)
and yes, I am assuming the charge is on the x axis
You should probably use a different variable then, so whoever is marking your assignment doesn't think that you are using it to represent the x-coordinate of the point charge.
Okay, but why?... If you want full credit for your solutions, you should always support any assumptions you make with reasonable arguments.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
