Electric flux - Area vector question
Electric flux is calculated using Gauss's Law, expressed as ψ=∫D·dA, where both D (electric flux density) and dA (differential area) are vector quantities. The confusion arises from the interpretation of dA as a vector, which is clarified by defining it as dA=n dA, where n is a unit vector normal to the surface. The angle φ between D and the normal vector affects the flux, as the component of D perpendicular to the area determines the flow through the surface. If the electric field is perpendicular to the surface, the flux is zero, illustrating the importance of direction in calculating electric flux. Understanding these concepts is crucial for applying Gauss's Law effectively.
okami11408
This is my first post here.
I have a problem dealing with Electric flux.
According to Gauss's Law, to find electric flux we use equation:
ψ=∫D dot dA, both D(Electric flux density) and dA(super small area normal to the surface) are vector quantity.
Now this is what I confused, how can "dA" be a vector quantity since it's an area.
I may misunderstand something.
Thank you!
The electric flux d\Phi through an area dA is defined as d\Phi=D\normalsize{d}A cos \phi.
\phi is the angle between the normal to the area and \textbf{D}.
D cos \phi is the component of D at right angles to the area.
We can write d\Phi=D\normalsize{d}A cos \phi more neatly, as
d\Phi=\textbf{D}.d\textbf{A}
if we define a vector d\textbf{A} such that d\textbf{A}=\textbf{n}dA.
Here, \textbf{n} is a unit vector normal to the area. If the area is part of a closed surface, we choose the normal pointing outwards from the enclosed volume.
Hope this helps. Congratulations on your first post. It is very clear.
http://www.technology2skill.com/science_mathematics/vector_analysis/vector_picture/curve_surface_integral_first.png This might be a helpful picture: Here k is a flux vector, and n is the unit vector normal to the surface.
The reason why dA is a vector quantity is the amount of electric flux moving through a given Gaussian surface depends not only on the magnitude of the electric flux, but also its direction. For example, if the E-field is flowing directly perpendicular to the gaussian surface, there can't be any flow through the surface, and the flux will be zero. (You can see why the dot product/cos is used here!)
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
