Electric Potential and velocity
The discussion revolves around a physics problem involving a charged ball's motion through a voltage difference. The key equation for conservation of energy is highlighted, showing the relationship between kinetic energy and electric potential energy. A sign error in the initial setup is identified, which leads to confusion in solving for the final velocity. Participants clarify that the initial voltage does not need to be known, as it cancels out in the calculations. The conversation emphasizes the importance of correctly applying the conservation of energy principle in electric potential scenarios.
Ryan060
A small ball has a mass of mass m 4.0 x 10^-8 kg and a charge of q = -2.0 x 10^-5 C. It enters a box with an initial speed of v0 = 1.0 x 10^4 m/s. The point where the charge leaves the box is at a voltage 350 kV higher than the entry point.
1/2mv^2(f)-1/2mv^2=qV(f)-qV(i)
1/2(4.0 x 10^-8)v^2-1/2(4.0 x 10^-8)(1.0 x 10^4)=q(V(f)-V(i))
1/2(4.0 x 10^-8)v^2-1/2(4.0 x 10^-8)(1.0 x 10^4)^2=-2.0x10^-5(3.5x10^5)
1/2(4.0 x 10^-8)v^2-(2)=-7 <-- there is were it all falls apart as you can see i will end up with a (-) under the sqrt and that is just a fail. I understood everything in physics right up until EP and now the emails i get from my professor are just useless. thanks for your help in advance. i am assuming that the 350kv is the V(f)-V(i) is this wrong?
[/B]
You have a sign error in your original equation. The electric potential energy U is equal to qV, so conservation of energy gives you
$$\frac{1}{2} mv_i^2 + qV_i = \frac 12 mv_f^2 + q V_f.$$
I rearranged the equation s subtracting qVi and KE(f) in that form i end up with 2 unknowns rewritten out :
2.0+-2.0x10^-5(Vi)=1/2(4.0 x 10^-8)v^2+-2.0x10^-5(Vi+3.5x10^5)
if i had Vi this would be easy should i be solving for that somehow ...i really don't get this. The lecture was a pretty much pointless activity and the book is 2 pages on this section so i feel pretty in the dark at the moment
You don't need ##V_i##. It cancels out.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
