Electric Resistance: Causes & Theory
  • Thread starter jobyts
  • Tags
    Electric
In summary, the electric resistance of a material is primarily caused by electron-phonon scattering, where the vibrations of the lattice collide with the moving electrons. This results in an increase in resistivity at higher temperatures due to more frequent scattering. The strength of the attachment of the electrons to the atoms and atomic bonds also play a role in resistance. It is possible to theoretically derive the resistance of a material without using voltage and current, and this can be calculated for metals and semiconductors. Additionally, there is a relation between electrical and optical resistance, and the lattice vibration can be observed experimentally through mathematical models.
jobyts
227
64
What causes electric resistance for a material (in terms of molecular or atomic level)?
Also, it should be possible to derive the resistance of a material by it's atomic/molecular properties theoretically, right? (without using voltage and current).
The strength of the attachment of the electrons to the atoms and at lower temperatures the strength of the atomic bonds.
At least for metals and semiconductors you can calculate the resistance.
In most material, at ordinary temperatures, it is due to the electron-phonon scattering. What this means is that the vibration of the lattice of the material collides with the movie electrons (or holes). This is why the resistivity increases as the temperature goes up. The higher the temperature, the more the lattice vibrates, the more frequent the electrons/charge carriers scatter.
Zz.
Zz.
Assuming it's the same lattice vibration you are talking in the FAQ section:
Is there a relation between the electrical and optical resistance for a given material? Does the electric resistance change if the material is placed under light?
Is there a way to experimentally see the lattice vibration on a computer screen?, or it is a mathematical model that could explain every phenomena.
1. What is electric resistance?
Electric resistance is the measure of an object's opposition to the flow of electric current. It is caused by the collisions of electrons with atoms in a material, which generates heat and decreases the flow of current.
2. What are the factors that affect electric resistance?
The factors that affect electric resistance include the material of the object, its length, cross-sectional area, and temperature. Materials with high resistance, longer lengths, and smaller cross-sectional areas tend to have higher resistance, while temperature can either increase or decrease resistance depending on the material.
3. How is electric resistance measured?
Electric resistance is measured in ohms (Ω) using an ohmmeter, which passes a small electric current through the object and measures the voltage drop. The resistance is then calculated using Ohm's law (R=V/I), where V is the voltage and I is the current.
4. What are the practical applications of understanding electric resistance?
Understanding electric resistance is crucial in designing and maintaining electrical circuits. It helps in selecting the appropriate materials, sizes, and lengths of wires and other components to ensure efficient and safe flow of current. It is also important in fields such as electronics, telecommunications, and power generation.
5. How can electric resistance be reduced?
Electric resistance can be reduced by using materials with lower resistance, shorter lengths, and larger cross-sectional areas. Additionally, keeping the temperature of the material low can also decrease resistance. In some cases, adding a conducting material, such as copper, can also help reduce resistance.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
16K
  • Electromagnetism
