How Do You Calculate Electrical Field Strength in Kapton Insulated Cables?
To calculate the electrical field strength in a Kapton insulated cable, the formula for a uniform field is used: Eb = (v/r(ln(r/R)), where Eb represents breakdown voltage per mm. The cable in question has a conductor size of AWG 24/19 with a 0.6 mm diameter and a Kapton wall thickness of 1.0 mm, operating at 15 kV DC. The field strength is highest at the conductor surface and decreases towards the insulation surface. For accurate calculations, the breakdown voltage strength of the insulation material must also be considered.
nastyboy
Dear All,
How do i calculate the Electrical field strength in v/mm for a Kapton Insulated Cable.
Conductor AWG 24/19 - 0,6 mm
Kapton wall thickness : 1,0 mm
Voltage : 15 KV
Thanks.
Here is a link to a Kapton wire mfg..
http://www.allectra.com/pdf/Kaptonwires.pdf
AC or DC ? In short, take the Kapton V/mil x wall thickness (For DC only)
Thanks Zapitgood for the Information.
The Voltage is DC.
How is the Fieldstrength of any cable calculated. ( according to AC or DC )
Coax / Twinax /
Since we know that for a Uniform Field
we have the formula
Eb = (v/r(ln(r/R))
Eb = breakdown Voltage pro mm
where the Field strength is maximum at the conductor surface and minimum at the Insulation surface.
If for example when the insulation is PTFE or any other materials
then the Field strength is according to the Breakdown voltage strength specified by the supplier of that material.
Thanks
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
