Electrical force between charges
The discussion centers on calculating the electrostatic force exerted by a charge (q1 = 3μC) at a distance of 3 meters. The initial calculation used the formula Feq1 = 1/(4πε0)*(q1/r), leading to a force of 89.9 kN, which seemed excessively large. Participants pointed out that the formula was incorrectly applied, as it should include r² in the denominator, reflecting the correct relationship for electrostatic force. The correct approach would yield the electric field strength rather than the force at a point. Clarification on the formula and its application was essential for resolving the confusion.
Latsabb
edit: I see that my title is incorrect. This isn't between charges, it is between a charge and a point, sorry about that.
The problem:
Find the magnitude of the electrostatic force that works on a point 3 meters from q1.
q1=3μC
My attempts:
Feq1=1/(4πε0)*(q1/r)
r=3m
1/(4πε0)=8.988x109
Feq1=8.988x109*(3x10-6/3)=89.9kN
As far as I can tell, this is the way it should be done, but the force seems pretty large... Is there something that I am missing? Or is this actually correct?
The problem:
q1=3μC
My attempts:
r=3m
1/(4πε0)=8.988x109
Well, you can start by checking the units in your calculation, in particular Coulomb's constant. Are your formula and calculation dimensionally correct?
Coulombs constant is N·m²/C², while q1/r would be C/m. So put together that would give me N*m/c... That means that there should be a C²/m², which I know to be q0*q1/r2 but that is between two charges, not the force at a point.
I guess that means that Feq1=1/(4πε0)*(q1/r) isn't an actual equation? Which leaves me confused, because that is what was given to me in someone's notes...
I spoke with the person I got the notes from, and it should have been r2 in the denominator, which would give me N/C, or the field strength. Thank you for your help.
