How are Electrical Permittivity and Magnetic Permeability Measured?
Electrical permittivity and magnetic permeability are defined through Maxwell's equations rather than directly measured. The speed of light (c) is related to these values by the equation c = 1/SQRT(eu). The magnetic permeability (u) is fixed by the definition of the Ampere, while the speed of light is defined in terms of the meter. Various methods, such as measuring capacitance or using dielectric spectroscopy, can be employed to determine permittivity in materials. Ultimately, permittivity and permeability can be calculated from known values of impedance and the speed of light.
Zman
Maxwell showed us that the speed of light in vacuum is dependent on two values.
The two values are the electrical permittivity and the magnetic permeability.
But how are these two values measured?
They aren't - it's the other way around, you define them from Maxwell's equations.
You can define electrical permittivity in terms of the speed of light and and the magnetic permeability. The magnetic permeability is fixed by the definition of the Amp and the speed of light is fixed by the definition of the metre.
Thanks for that. But I am still unclear.
The equation relating c, permittivity of free space (e) and permeability of free space(u)
c = 1/SQRT(e u)
Are you saying that knowing c from experiment, and u from something else, then the value of e is found?
Yes
\mu is fixed at 4 \pi 10 ^{-7} from the definition of the Amp (the 10^-7 is because it was originally in cm and g rather than kg and m)
The speed of light is fixed, the metre is now defined in terms of the speed of light (so if a new measurement is made of c we change the length of the metre)
But it is of course also possible to just measure the capacitance of a capacitor of known calculable) geometry (or, if you need accurate results, to use a cavity perturbation method).
I've never heard of anyone actually measuring the relative permittivity in a material by directly measuring the speed of light.
Dielectric spectroscopy is HUGE field and there are many different ways to measure permittivity.
By measuring the impedance of an air-dielectric coax cable of known geometry (e.g., Andrew HJ7-50A heliax) or other transmission line geometry, the impedance of free space (Z0 = 377 ohms) can be estimated.
Then solve
sqrt(u0/e0) = Z0 = 376.730 ohms.
Then knowing the speed of light 1/sqrt(u0 e0) = c = 2.9979 x 108 meters per sec
e0 and u0 can be calculated separately.
u0 = Z0/c = 4 pi x 10-7 Henrys per rmeter
e0 = 1/(Z0c) = 8.85 x 10-12 Farads per meter
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
