How Much Electrical Power Does a 75% Efficient Pedal-Operated Generator Produce?
The discussion revolves around calculating the electrical power produced by a 75% efficient pedal-operated generator driven by an 80kg man. The man climbs a staircase 3.0 meters high in 8.5 seconds, generating a force of 800N. The total work done is calculated as 2400J, leading to an initial power output of 282.4W. After accounting for the generator's efficiency, the final electrical power output is determined to be 211.8W. The calculations and methodology presented appear to be correct.
lemon
Hi:
Would somebody please check to see if I am on the right track with this problem.
Many thanks
An 80kg man on a step-exercise machine climbs a staircase 3.0m high in 8.5s. If he works at the same rate to drive a pedal-operated generator with an efficiency of 75%, how much electrical power would be produced?
power=work done/time taken
efficiency=useful energy output/total energy input
work=force x displacement in direction of force
F=ma
weight=mg (gravity=10ms ^-2)
F=80 x 10 =800N
Work done (W)=800 x 3.0 = 2400J
Power=2400/8.5 = 282.4W (1d.p.)
therefore
75% x 282.4 = 211.8W
F=
looks good
thank you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
