Electricity and Magnetism question
To calculate the magnetic flux through the circular cross-sectional area of a solenoid, the magnetic field can be determined using the formula B = μ₀NI/L, where μ₀ is the permeability of free space, N is the number of turns, I is the current, and L is the length of the solenoid. The total magnetic flux linked with the solenoid is given by the equation φ = NAB, where A is the area of the cross-section. However, if the question specifically asks for the flux through a single turn, the total flux should be divided by the number of turns (N). It's important to note that the formula for B is applicable only for long solenoids, which the given dimensions suggest is valid in this case. The discussion clarifies the distinction between total flux and flux through a single turn, emphasizing the need for accurate interpretation of the problem.
matt85
A solenoid 2.9 cm in diameter and 15 cm in length has 300 turns and carries a current of 5 A. Calculate the magnetic flux through the circular cross-sectional area of the solenoid.
-->> I tried using the equation B = u(0)NI/L to calculate magnetic field, and then putting this in the formula flux = BNA, where N is number of turns, and A is area (pi*r squared). This didn't work, though.
I'd appreciate some help! Thanks!
The field is indeed given by
B=\frac{\mu_{0}NI}{L}
and the total flux through the solenoid
\phi=NAB is also right.
Maybe what they asked for is the flux through a single turn which would be your answer divided by N
Also keep in mind that
is valid only for a long solenoid. (When its length is large compared to its radius)
I feel your solenoid is long enough. I don;t see why you're not arriving at the answer.
yep, it was wanting it through one turn. thanks.
matt85 said:
... Calculate the magnetic flux through the circular cross-sectional area of the solenoid...
I think NBA is the total flux linked with the solenoid, not the flux through the cross-section. It is BA only.
MP
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
