Can Sea Waves Provide a Reliable Source of Electricity Year-Round?
  • Thread starter Thread starter rajeshmarndi
    Electricity Waves
Electricity can be generated from sea waves, which are a constant energy source, but several challenges hinder its widespread implementation. The variability in wave height and direction complicates the design of generating systems, requiring adaptability in mooring designs. Additionally, transporting the generated electricity to shore poses logistical issues similar to those faced by wind energy. Research has shown that not all coastal areas have sufficient wave height to produce a significant amount of power consistently. Despite the potential, technological and economic barriers have prevented wave energy from becoming a mainstream energy source.
rajeshmarndi
why can't electricity be generated from sea waves which are available through out the year.
What is required for generating electricity is a source of energy that can rotate a turbine, which the sea waves are definitely capable. So what is the hurdles faced in this direction generating electricity.
Thanks.
It can be, and there are efforts in place to do just that. Check out the Wikipedia article on Wave power.
One of the first jobs I had after graduating college was working for a small engineering firm consulting on a wave-energy generation project. This was 30+ years ago.
Although waves are present 'all the time', they are variable in height and direction throughout the year. The generating array must be able to adapt to the change in the direction of the waves, which complicates the mooring design. Also, once a wave has generated some electricity, you've still got to get the electricity ashore. Just like with wind turbines, the variability of the winds and the waves means that the generated power is constantly fluctuating, which is not desirable.
Can't the turbine be restricted to rotate at a minimum speed i.e the minimum power which is always available.
I think wind may not be there always with the wind mill, but sea waves never stop, they can fluctuate with distances from the sea shore. I see sea waves as the only source that we see in nature which act like a perpetual machine.
Waves do stop now and then. Tides don't.
http://en.wikipedia.org/wiki/Tidal_power
But in general you are neither first, nor the last to think about harvesting waves power. I remember reading about them in seventies, and I am quite sure the idea appeared much earlier. As I see it mentioned now and then, I am more than sure people did a lot of research and if the thing is still not popular and widely used, it most likely means it is technologically challenging. Doesn't make it impossible to use - just the price of the energy can be too high.
If we are talking about wind turbines, how exactly do you restrict a wind turbine to rotate at minimum speed? If the wind doesn't blow, you can't spin the turbine.
Sorry, but you are not clear when you say 'sea waves never stop'. We also don't discuss Perpetual Motion at PF, either.
The wave height is a key measure of how much power can be extracted by a wave generator from the sea. If you are dealing with waves which all have only a small height, you can't generate much power. In fact, a lot of the studies done with the wave generator project I was involved in had to do with assessing which areas around the world had waves of sufficient height for a significant part of the year which would allow for the generation of a certain minimum amount of power. Not every place studied could meet the criteria chosen.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
