Confusing Electricity: Uncovering the Mysteries of Voltage and Resistance
High-voltage stun guns, such as those rated at 4.5 million volts, do not produce lethal currents due to their design, which includes capacitors that release a small amount of charge quickly, causing voltage to drop sharply after initial contact. The confusion around resistors arises from the fact that adding resistors in parallel decreases total resistance, allowing for increased current flow, while series connections increase resistance. Voltage acts as the driving force for current, and sources have limits on how much voltage they can maintain under load. The discussion emphasizes that despite high voltage ratings, the actual current delivered is minimal and typically not lethal. Understanding the relationship between voltage, current, and resistance clarifies why devices like stun guns are designed to be non-lethal.
Krb686
Well I guess it's pretty simple, I know E = IR, but I've been thinking of some situations lately that have been confusing me so I decided to ask here. The first one is how does a high voltage stun gun not create high currents? The highest I've seen is 4.5 million volts. I think they simply can't kill you because it is 4.5 million volts rated between the two prongs so the electricity only travels an inch or two correct? My finger reads 7 million Ohms over an inch, which would mean if I stuck that stun gun there it would create .65 Amps right?
The second questions is since when you add resistors in series, the total resistance drops, why couldn't you just keep adding resistors until you have an extremely low resistance and create high currents off of low voltages? And how does it make sense that adding more resistors drops overall resistance anyways?
Dunno from stun-guns. Maybe the spec'd voltage is the un-loaded, before you unload on someone's butt, value. There could be just a few electrons even at 4.5MV, so the current would be minimal.
But to the resistors. Firstly, resistors in _parallel_ decrease the total resistance. You can imagine it as increasing the number of paths for current to flow. As you keep adding resistors, more current flows. However you are not "creating" current flow. The voltage (think of it as pressure) is creating the flow, and the source will always have a limit on how much it can push. As you approach that limit the voltage will begin to drop, or your resistors will melt, whichever happens first.
Okay that makes sense now, sorry I mistyped that I meant to say in parallel.
I don't get where the confusing part is.
The stun guns have capacitors which hold very little charge, its not an infinite power source so the V drops exponentially. It would start at 650mA or whatever you got, but drop very quickly, that's why it won't kill you (most likely).
I heard of cases where stun guns killed, but maybe its the police brutality propaganda or what not.
What do you mean it would drop? I thought it would just carry 650 milliamps constantly through wherever on your body it was touching.
lololol no no no no. Its not an ideal voltage source. The 4.5 million volts is for an instant, and drops sharply.
When you rub your cat with a balloon you have a potential of about 10 million volts or so on the balloon, but it never kills you. The amount of CHARGE is very small (learn about charge, unit is coulomb) and the energy is small also.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
