Solve Electricity Numericals with Expert Help: Hydrogen Discharge Example
  • Thread starter Thread starter saltrock
    Electricity
The discussion revolves around solving a hydrogen discharge electricity numerical problem involving current calculation. The current is determined using the formula Q=I x t, where the charge of electrons is essential for the calculation. Participants suggest looking into the concept of 'Conventional Current flow' to understand the direction of current. There is also a recommendation to post homework questions in a designated help section for more focused assistance. Overall, the thread emphasizes the importance of understanding basic electrical principles to solve the problem effectively.
saltrock
electricity numericals! help needed!
When a sufficiently high voltage is applied between two electrodes in a gas, the gas ionises. Electrons move towards the positive electrodes,and positive ions move towards the negative electrode.
a) what is the current in a hydrogen discharge if, in each second, 4.4 x 10^15 electrons and 1.5x 10^15 protons move in opposite directions past a cross-section of the tube?
b)what is the direction of the current? :confused:
This sounds like a homework problem.
Tell us what your thoughts are on the problem.
a) Start with Q=I x t
You should know the charge on an electron.
b) Look up 'Conventional Current flow'.
c) Post HWK in the HWK help section.
thanx for your help.
No problem.
