Electromagnetic Induction - rod on two parallel tracks, force varies
The discussion revolves around a physics problem involving two parallel wires and a sliding wire in a magnetic field. The key challenge is to determine the velocity of the sliding wire as a function of the distance traveled, given that the force acting on it varies with velocity. The induced electric current from changing magnetic flux complicates the situation, as it introduces an additional force. Participants suggest calculating the force using the relationship F=ma and integrating to find the velocity, but express uncertainty about how to accurately compute the force due to its variability. The conversation highlights the complexities of electromagnetic induction and the need for a clear approach to solving the problem.
dharavsolanki
Two infinite parallel wires, having the cross sectional area 'a' and resistivity 'k' are connected at a junction point 'P'. A slide wire of negligible resistance and having mass 'm5 and length l can slide between the parallel wires, without any frictional resistance.
If the system of wires is introduced to ' a magnetic field of intensity "B" (into the plane of paper) and the slide wire is pulled with a force which varies with the velocity of the slide wire
as F = F0V, then find the velocity of the slide wire as a function of the distance travelled. (The slide wire is initially at origin and has a velocity v0)
Relation between flux and induced electric field.
Force on a current carrying conductor in a magnetic field.
Relation between resistance and resistivity, length and cross sectional area.
Calculus?
When the rod is moved, flux changes and the electric current is induced, which introduces another force. But the force on this is variable. How do I solve the question in such a situation?
I think we need to calculate the force, and then use the equation F=ma to get the acceleration. Then integrate this to get the velocity as a function of distance. But I'm not sure how to calculate the force.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
