What is the curl of the electric field produced by changing magnetic flux?
The discussion revolves around the nature of the electric field generated by changing magnetic flux, which is described as nonconservative. The curl of a conservative field is zero, while the curl of the electric field due to a time-varying magnetic field is non-zero, as indicated by Faraday's Law, a key equation in Maxwell's equations. The conversation highlights the importance of understanding vector calculus and the context of the question to provide a more accurate explanation. Additionally, the original poster is encouraged to clarify their knowledge level and the specific textbook referenced. Understanding these concepts is crucial for grasping the relationship between electric and magnetic fields in electromagnetic theory.
Xubi
My book says that the electric field produced by changing magnetic flux is nonconservative in nature but it doesn't give any explanation.
1. If field F is conservative, what is the curl of F?
2. So if E is present due to time varying B field, i.e. dB/dt is not zero, what is the curl of E? Look up the differential form of Faraday's Law (i.e. one of Maxwell equation).
Please note that your question gave no clear indication of your level of knowledge or what you know. So I have to assume that you know (i) vector calculus and (ii) Maxwell equation.
Otherwise, you should have been very clear on what book you are referring to and what level this is at.
Zz.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
