Electromagnetic Potential as an Observable
jfy4
Hi,
I suppose I'm a little late to start here, but I just got hung up on the following: The field quanta in E&M is the photon and it comes from the gauge potential in QED A(x)
<br /> A(x)=\int \frac{d^3 p}{(2\pi)^3 \sqrt{2\omega_p}}\sum_{\lambda=1,2}\left[ \epsilon(p,\lambda)a_{p,\lambda}e^{-ipx}+\epsilon^{\ast}(p,\lambda)a^{\dagger}_{p. \lambda }e^{ipx} \right]<br />
which is an operator on the fock space that creates a particle with helicity 1, momentum k, energy |k|, and no mass, the photon. But classically the potential A is not an observable, so how come the photon is an observable?
Thanks,
But A is observable classically! Specifically, the combinations
-\nabla \phi + \partial_t \vec A, \qquad \nabla \times \vec A
are observable. A has extra gauge degrees of freedom. But the true degrees of freedom, after removing the gauge redundancy, are observables. You'll notice that after removing the gauge redundancy, A (a four-vector) has two remaining degrees of freedom; these are exactly the two observable polarizations of light.
Thanks Ben,
That's what I thought, that A is observable after preforming those operations on it. I specifically recall that the potential field cannot be directly observed, only the field strength tensor, which is what you have above.
Thanks,
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
