Electromagnetism Current Curcuits
The discussion focuses on analyzing a circuit with four resistors connected to a battery, detailing the potential differences and currents through each resistor. The potential difference across the resistors is ranked as R2 < R1 < R3 < R4, with specific values calculated in terms of the battery's emf. The current through the resistors is ranked as I1 > I4 > I2 = I3, with corresponding current values derived in relation to the total current I. An increase in R3 results in an increase in I4 while I1, I2, and I3 decrease. In the limit where R3 approaches infinity, the expected current values for the resistors need clarification, particularly for I1 and I4.
JJBrian
Four resistors are connected to a battery as shown in the figure. The current in the battery is I, the battery emf is emf, and the resistor values are R1 = R, R2 = 2R, R3 = 4R, and R4 = 3R.
Picture:
http://www.webassign.net/serpop/p21-32.gif
(a) Rank the resistors according to the potential difference across them, from largest to smallest. (Use the form R1 for R1.)
R2<R1<R3<R4 (Correct)
(b) Determine the potential difference across each resistor in terms of emf. (Use E for emf, as necessary.)
ΔV1 = E/3 Answer is correct.
ΔV2 = 2E9 Answer is correct.
ΔV3 = 4E/9 Answer is correct.
ΔV4 = 2E/3 Answer is correct.
(c) Rank the resistors according to the current in them, from largest to smallest. Note any cases of equal currents.
I1 > I4 > I2 = I3 Answer is correct.
(d) Determine the current in each resistor in terms of I. (Use I, as necessary.)
I1 = I. Your answer is correct.
I2 = I/3. Your answer is correct.
I3 = I/3 Your answer is correct.
I4 = 2I/3 Your answer is correct.
(e) If R3 is increased, what happens to the current in each of the resistors?
I4 increases and I1, I2, and I3 decrease. Your answer is correct.
(f) In the limit that R3 → infinity, what are the new values of the current in each resistor in terms of I, the original current in the battery? (Use I, as necessary.)
I1 = I Your answer is incorrect.
I2 = 0. Your answer is correct.
I3 = 0. Your answer is correct.
I4 = I. Your answer is incorrect.
I would like some help on part (f).
You are correct .
