Electromagnetism qs need someone to check my work
An electron is accelerated by a potential difference of 10,000 V, resulting in a speed of approximately 5.9 x 10^7 m/s before passing through two plates with a potential difference of 200 V. The calculations for the time spent between the plates and the resulting acceleration are questioned, particularly the omission of the 200 V in determining the electron's trajectory. The acceleration is recalculated based on the electric field created by the plates, which affects the electron's motion. The final angle of travel is computed to be 3.4 degrees, but concerns about the accuracy of the calculations remain due to the potential oversight of the 200 V influence. The discussion emphasizes the need for a more thorough analysis of the forces acting on the electron.
crosbykins
An electron is accelerated horizontally from rest in a television picture tube by a potential difference of 10,000 V. It then passes between two horizontal plates 5.0 cm long and 1.0 cm apart which have a potential difference of 200 V. At what angle θ will the electron be traveling after it passes between the plates?
-ΔEE = ΔEK
-ΔEE = ΔEK
qΔV = 1/2mv^2
√ (2qΔV)/(9.1*10^-31kg) = v
√ (2(1.6*10^-19 C)(10 000V))/ (9.1*10^-31kg) = v
5.9*10^7m/s = v
Δt = .06m/5.9*10^7 m/s
= 1.0*10^-9 s
acceleration = qv/md
= [(1.6*10^-19 C)( 5.9*10^7m/s)]/[(9.1*10^-31kg)(.01m)]
= 3.5*10^15 m/s^2
v2 = a Δt
= (3.5*10^15 m/s^2)( 8.5*10^-10 s)
= 3.5*10^6 m/s
θ = tan-1 [(3.5*10^6 m/s)/( 5.9*10^7m/s)]
= 3.4
The electron will be traveling at an angle of 3.4.
***is this right?
Don't you find it strange that you never use the 200V potential difference in your calculations?
I don't think that this answer is correct, I have not calculated it but the absence of the 200V and how you calculate your acceleration rings warning bells for me. Can you see what equation you should use to calculate the acceleration (think about in what direction is the acceleration of the electron)?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
