Electromagnets and pole shifting
The discussion addresses the determination of poles in a solenoid electromagnet, clarifying that the pole orientation depends on the winding direction of the coil and that reversing the battery will indeed reverse the poles. It also explores the magnetic fields created by parallel wires carrying current, noting that if the wires are part of the same circuit, they effectively behave as a single larger wire. The interaction of magnetic fields from two wires can lead to complex field patterns, especially if currents flow in opposite directions. Overall, the conversation emphasizes the importance of understanding electromagnetism principles, such as the right-hand rule, to predict magnetic behavior in circuits. This foundational knowledge is crucial for anyone studying electromagnetism and its applications.
Mr_Bojingles
I read a couple of tutorials on electromagnetism and solenoids but there's a good few questions left unanswered.
1.) What determines the poles of a solenoid electromagnet? Let's say I have direct current flowing from the left end of the coil to the right. Will the north pole automatically be on the left end of the solenoid or the other way around?
If I turn the battery around will that reverse the poles?
2.) Say I have a long circuit with the wires places side by side so the two wires run parallel. Let's say there's a heavy current running through the circuit.
Battery================Resistor
Since there's a small magnetic field surrounding the wire through the whole circuit and the wires are close enough that their magnetic fields overlap. Would it create 2 poles one at the battery end and one at the resistor end?
This site might cover everything that you want to know. I didn't check it all out, but the beginning is good. Your 2-wire problem, as far as I know, isn't a problem at all. If they are following the same path, they essentially act as one larger wire. That's how stranded cables work.
http://library.thinkquest.org/13526/c3c.htm"
1) Depends on which way the coil is wound.
Look up the right hand rule.
1A) Yes.
2) What does the field look like around a single wire?
Using the right rule, what is different about the field on wire A and the field on wire B.
What do you think happens when you overlap the two fields?
The current will be going in one direction in one wire and the reverse direction in the other wire.
If the current was going the same direction in both wires then you would be correct.
Ooops! Sorry, I misunderstood the question. I didn't realize that he meant that the second wire was the return path.:redface:
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
