Electron Energy in Compton Collision
To achieve an electron energy of 25 keV in a Compton collision, the minimum initial photon energy required is 138 keV. The discussion highlights the use of conservation of momentum and energy equations to determine this energy. It is assumed that the photon collides with a stationary electron and bounces back, simplifying the problem to one dimension. The relationship between the initial and final frequencies, along with the electron's velocity derived from its kinetic energy, allows for solving the equations. Overall, the calculations focus on determining the initial photon frequency needed for the desired electron energy.
Quelsita
Question:
You want to give an electron an evergy of 25kev in a Compton Collision. What is the minimum initial photon energy you need?
Equations:
\Delta\lambda= h/mec(1-cos(\theta))
E=mc2
E=hv=hc/\lambda
I'm not really sure where to start from here. I know the answer is 138kev but I am not sure how to go about getting it.
For the Compton Effect, you have two equations: conservation of momentum and conservation of energy. I would assume the photon hits a stationary electron and bounces straight back, so only one dimension to consider and no doubt this situation gives you the minimum photon energy.
The two equations involve the initial frequency, frequency after the collision, and the velocity of the electron. But you can find the velocity from the given KE, so you have only two unknowns in your two equations. It looks straightforward to solve for hf1.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
