How Does Electron Scattering Work in Crystalline Nickel Foil?
The discussion focuses on the scattering of electrons in a crystalline nickel foil, specifically addressing calculations related to electron speed, de Broglie wavelength, and scattering behavior. Participants are tasked with determining the speed of electrons with 50 eV and 50 MeV kinetic energy, as well as explaining the observed intensity peaks in scattered electrons due to constructive interference, referencing the Davisson-Germer experiment. The conservation of momentum in elastic scattering events is also questioned, with an emphasis on the angles of emitted particles. The 100 nm thickness of the foil is noted as significant for understanding scattering dynamics. Overall, the thread seeks assistance with the more complex aspects of the problem, particularly regarding scattering and momentum conservation.
jecyca2003
A beam of electrons with kinetic energy 50 eV is fired at a 100 nm thick crystalline nickel foil.
  1. (a) Calculate the speed of the electrons in the beam.
  2. (b) Based on your answer to part (a), state, with justification, whether classical (Newtonian) mechanics correctly describes this system.
  3. (c) Determine the de Broglie wavelength of the electrons.
  4. (d) Electrons incident on the nickel are scattered. The scattered electrons show strong peaks in intensity at particular orientations of the incident beam to the nickel target. Explain, with the aid of a detailed sketch, how this can be accounted for.
    The energy of the electrons is now increased to 50 MeV.
    1. (e) Repeat (a)-(c) above for these electrons, and from your results explain why the majority of electrons pass straight through the foil. You may find it useful to know that hc/2π = 197 MeV fm.
    2. (f) Occasionally one of the beam electrons elastically scatters from an atomic electron in the foil. Is momentum conserved in such reactions? Explain in words why the products of the reaction are not emitted at 90 degrees to one another.
KE = 1/2 (m)(v^2)
λ = h/√(2KEm) (deBroglie Wavelength Equation)
For part a) and c), I just plugged the numbers into the equation. I am not quite certain why the question emphasizes 100nm.
I am stuck mainly with the second half of the question d), e), and f). It would be very nice to get some help for those questions.
look up the davisson gemer experiment. the peaks correspond to constructive interference from the scattered electrons.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
