Electronics Repair: Just an Observation
  • Thread starter Thread starter trini
    Observation
When repairing electronics, disassembling and reassembling devices can sometimes restore functionality, possibly due to issues like corrosion or loose connections. Cleaning dust and grime is also essential for optimal performance. Interestingly, some users report that devices may malfunction temporarily but work again after a period of inactivity. This has led to humorous anthropomorphizing of circuits, suggesting they may feel "lonely" or even "malicious." Ultimately, regular maintenance and cleaning are crucial for keeping electronics in working order.
trini
Ok so I've noticed in my time playing with electronics, which isn't that long, that sometime when something breaks and i just take it apart, pretend i know what I am looking for, and put it back together, it usually works. maybe circuits just feel lonely sometimes?
Sometimes, it's just the corrosion or loosening of joints / wiring / connections. That or a necessary cleaning out of dust / grime / etc., as I tend to do.
Thar's plenty of that available for cleaning at Studio T, any time.
:smile:
I'll agree with the lonely explanation. In fact I had two electronic "art pieces" that I checked and cleaned before a recent party. Neither worked, even after multiple fiddles, during the party. They both worked fine the next day. So I'd bump up the anthropomorphizing to "malicious".
Never anthropomorphize circuits. They hate it when you do tha. :wink:
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
