Electrons in rectilinear uniform motion
Electrons in rectilinear uniform motion will indeed interact with an external magnetic field, causing their paths to curve rather than remain straight. This phenomenon explains the distortion seen on older tube televisions when a magnet is brought close, as the electrons deviated from their original trajectory impact the screen differently. Although the motion of electrons is approximately uniform, energy loss occurs during acceleration, complicating their behavior. Caution is advised against performing such experiments at home, as they can damage screens permanently. Overall, the interaction between moving electrons and magnetic fields is a fundamental concept in electromagnetism.
crx
Im wondering if electrons in rectilinear uniform motion will 'feel' an external magnetic field...?
Yes, they will, but once they enter a region of non-zero magnetic field, they will no longer be in rectilinear motion. Their path is curved.
Yes they will.
This is the reason why image gets distorted when you bring a magnet close to one of those "old" tube-televisions. Electrons hit the screen in order to produce the collors you see. They're in a (approximately) uniform rectilinear motion (they really aren't, since there's always some energy lost when accelerating charges). When you bring a magnet close to it, the electrons are deviated from original path, and you will see some distortion in the image.
I don't recommend you try this at home if you still want to use the television after the experiment (I've done this a few times as a child, and once I did it in the computer screen - WOW, it was really fun. Pity it left a permanent damage in the screen, and my parents didn't share the same artistic tastes as me). I've seen this experiment in one of Walter Lewin's lectures in MIT's OCW, but I'm sure you may find it in Youtube as well.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
