Electrostatic force and Gravitational force
The discussion centers on comparing electrostatic and gravitational forces between two charged particles, each with a charge of +5.0x10-9 C and a mass of 0.060 kg, separated by 3 cm. The calculated electrostatic force is 2.5x10-4 N, while the gravitational force is significantly weaker at 2.668x10-10 N. Despite the gravitational force being much weaker, it has a broader influence, governing the motion of celestial bodies and the structure of the universe. The relationship between these forces can be explained through their respective formulas, highlighting gravity's long-range effects compared to the localized nature of electrostatic forces. Understanding these differences is crucial in physics, particularly in astrophysics.
MartinaCilia
I have physics homework and came across this question :
I was asked to find the electrostatic force between two charged particles each having a charge of +5.0x10-9 C and which were separated by a distance of 3cm. I found it to be 2.5x10-4 N.Then I was told to calculate the gravitational force given that the two charged particles have a mass of 0.060kg. I calculated the gravitational force to be 2.668x10-10 N Finally I was asked this question :
Although the force of gravity is much weaker than the electrostatic force, it has a far more reaching effect. Explain.
Can anyone kindly tell me the answer to the last part of the question please ? I thought that maybe the answer should be derived from the two formulae of the respective forces, maybe?
Consider the forces that interconnect planets and stars and galaxies.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
