Electrostatics - metal sphere potential
A metal sphere of radius R1 is initially charged to 10V and then connected to a larger sphere with radius R2 equal to 2*R1. The final potential of the connected spheres is determined by distributing the charge so that their potentials are equal. The calculations show that the potential of the connected spheres is V_connected = V/2, which simplifies to 5V. This conclusion aligns with the principle that when two conductors are connected, they share charge until their potentials equalize.
xwhyy
Hi,
again very simple problem
Metal sphere of radius R1 is charged to 10V.
It is then connected to another sphere with R2 = 2*R1.
What is the final potential?
V = E * distance
so in the case of disconnected it is E*R1
when connected R's sum up so it would be E*(R1+R2)
and since I don't know E but R2=2*R1
it is E*3*R1 so my solution is:
V_connected = V * 3
Is that correct?
If it's correct, that's only a coincidence.
What is the potential of a sphere of radius R1 and charge Q?
Set that equal to 10V and solve for Q.
Then distribute the charge over the two spheres so that their potentials are equal.
Thank you for your reply!
so:
V = Q / [4*pi*epsilon*r1]
Q = V * 4* pi * epsilon * r1
V_connected = (V * 4 * pi * epsilon * r1) / ( 4 *pi * epsilon * 2 * r1)
which after simplification is equal
V_connected = V/2
is that true? :)
hop hop
Looks good. BTW: V = 10 Volts
When they're connected: V1 = V2 and Q1 + Q2 = Q = V·4πε0·R1.
