Is Evaporation a Physical or Chemical Change?
In summary, we discussed various topics related to physical and chemical properties of matter. We learned that when a cotton ball dipped in alcohol is wiped across a tabletop, the alcohol molecule evaporates, making it a physical change. We also found out that 1 gram of ice, liquid water, and water vapor all occupy the same volume. Oxygen is liquid and nitrogen is gas at 80k. We then looked at examples of physical and chemical properties, such as graphite conducting electricity and a bronze statue turning green. We classified changes as physical or chemical, and identified the chemical formula for compounds such as dihydrogen sulfide and barium
likewhoa
Hello everyone I was wondering if someone can check out my answers thanks!
1. A cotton ball is dipped in alcohol and wiped across a tabletop. Explain what happens to the alcohol molecule deposited on the tabletop. Is this a physical or chemical change? The alcohol molecule evaporates, therefore it is a physical change.
2. Which occupies the greatest volume: 1 g of ice, 1 g of liquid water, 1g of water vapor? they are all the same.
3. Oxygen O2, has a boiling point of 90k and nitrogen N2 has a boiling point of 77k. Which is a liquid and which is a gas at 80k? Oxygen is liquid and nitrogen is gas.
4. State whether each of the following is an example of of a physical or chemical property of matter.
a. graphite conducts electricity. chemical
b. bismuth, Bi, loses its iridescence upon melting. chemical
c. a copper penny is smushed into an embossed souvenir. physical
5. State whether each of the following is an example of of a physical or chemical property of matter.
a. carbon dioxide escapes upon the opening of a soda can. chemical
b. a bronze statue turns green. chemical
c. a silver spoon tarnishes. chemical
6. Classify the following changes as physical or chemical. Even i you are incorrect in your assessment, you should be able to defend why you chose as you did.
a. Grape juice turns to wine. chemical
b. Wood burns to ashes. chemical
c. water begins to boil. physical
d. a broken leg mends itself chemical
e. grass grows chemical
f. infant gains 10 pounds chemical
g. a rock is crushed to powder. physical
7. What is the chemical formula for the compound dihydrogen sulfide? H2S
8. What is the chemical name for a compound with the formula Ba3N2? Barium nitride
9. What is the common name for dioxygen oxide? O2
- They are all the same mass, but are they the same volume?
9. What is the common name for dioxygen oxide? Recheck this one and the next~
What are the basic elements of chemistry?
The basic elements of chemistry are oxygen, hydrogen, carbon, nitrogen, and sulfur. These elements are essential for life and make up the majority of known substances on Earth.
How many elements are there in the periodic table?
There are currently 118 known elements on the periodic table. These elements are organized based on their atomic number, properties, and electron configurations.
What are the three main categories of elements?
The three main categories of elements are metals, nonmetals, and metalloids. Metals are typically shiny, conductive, and malleable, while nonmetals are often dull, non-conductive, and brittle. Metalloids have properties of both metals and nonmetals.
What is the difference between an element and a compound?
An element is a pure substance made up of only one type of atom, while a compound is a substance made up of two or more different types of atoms bonded together. Elements cannot be broken down into simpler substances, but compounds can be broken down into their individual elements.
Why is it important to understand the elements of chemistry?
Understanding the elements of chemistry is crucial for understanding the world around us. Chemistry helps us understand how different substances interact and how they can be used in various applications, such as medicine, technology, and agriculture. It also helps us understand the composition and behavior of the universe.
19K
29K
