How To Find Angular Momentum of Elliptical Orbits
  • Thread starter Thread starter carbon_mc
    Orbits
To find the angular momentum of an object in an elliptical orbit, the formula used is L = r × mv, where L is angular momentum, r is the distance from the center of the planet, m is the mass, and v is the velocity of the orbiting object. The vector cross product is essential, particularly at the apogee and perigee, where the angle between the position vector and velocity vector is 90 degrees, simplifying the calculation to L = mvr. Understanding the relationship between these variables is crucial for accurate computation. The discussion also touches on whether a relativistic version of the equation is needed, but the classical approach suffices for most cases. This method effectively illustrates the conservation of angular momentum in elliptical orbits.
carbon_mc
Hey there is one question I have that has been burning in my mind. I know that in elliptical orbits of satellites/ spacecraft s/planets around a planet, angular momentum and energy is conserved, but how do we find that angular momentum only knowing the velocity of the orbiting object, its mass and its distant from Earth's surface? thank you
Astronomy news on Phys.org
In classical (non-relativistic) mechanics, you find the angular momentum using the definition in terms of vectors:
\vec L = \vec r \times m \vec v
Do you know about vectors and the vector cross product? Are you specifically looking for a relativistic version of this equation?
There are two points, the apogee and the perigee, where the angle between v and r is 90 degrees, so if you know the magnitudes of v and r at either one of those two points, the magnitude of the cross product simplifies to the scalar expression mvr. I don't know if that will be helpful, but I happen to remember reading about it.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
