Why is a Resistor Needed in an Emitter Follower Bias Current Circuit?
  • Thread starter Thread starter nylonman
    Bias Current
In an emitter follower circuit, a resistor is essential for providing a DC path for base bias current, especially when the signal is capacitively coupled. Without this resistor, the capacitor can charge up, leading to a negative voltage at the base that biases the transistor off, resulting in no output. The resistor allows the capacitor to discharge between input cycles, enabling base current to flow during voltage peaks. This setup can lead to significant distortion, which is sometimes utilized in frequency multiplier circuits. Thus, the resistor is crucial for maintaining proper transistor operation and preventing output loss.
nylonman
Hi, I'm reading The Art Of Electronics and I saw this in the emitter followers section:
"Warning:
You must always provide a dc path for base bias current, even if it goes only to ground... if the signal is capacitively coupled, you must provide a resistor to ground (Fig. 2.18)."
Here is the figure: http://imageshack.us/photo/my-images/38/figurep.png/
Could someone explain me why the resistor RB is needed?
Any help will be appreciated!
If it were missing where would the current path be for the bias current?
ok, I see it, it was simpler than I thought. Thanks!
That circuit is used rarely because it generates a lot of distortion. To avoid this, a base bias resistor is usually placed between the +ve supply voltage and the base.
However, if you did use this circuit, and omitted the resistor to ground, then the capacitor would charge up on the first few cycles of input (via the base-emitter junction) and the base would have a negative voltage on it of about the peak value of the input signal.
This would bias the transistor off and there would be no output.
Using the resistor allows the capacitor to partly discharge between cycles of input and base current would flow on input voltage peaks.
The output will be very distorted and this is sometimes used in frequency multiplier circuits.
ok, so in other words you are saying that we need the resistor in order to discharge the capacitor since the transistor emitter allows the current to flow only in one direction, right?
Yes, the base emitter junction acts like any other diode and charges up the capacitor to the peak value of the input signal. After that, the transistor cannot be driven into base current, so there is no output.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
