dacruick
- 1,038
- 1
Use a follower with base driven from a voltage divider to provide a stiff source of +5 volts from an available regulated +15 volt supply. Load current (max) - 25mA. Choose your resistor values so that the output voltage doesn't drop below more than 5% under full load.
So I have to choose the base to be at 5 volts using R1 and R2. I'm fine with that. R2/(R1+R2) = 1/3.
Then the Emitter voltage will sit at about 4.4V. So I have to choose R3 to give 25mA when 4.4 volts are across it. That gives me 176 Ohms.
What I'm confused about is how to choose resistor values to get a less than 5% voltage swing. Someone mentioned to me that a rule of thumb is to make the current through the voltage divider 10 times the output current. But then I have R1 R2 and R3, and I don't know how to check if the voltage swing parameter is met.
Any help is greatly appreciated
