Chemistry Empirical and Molecular Forumla calculation
Reductic acid has a composition of 52.63% carbon, 5.30% hydrogen, and 42.07% oxygen by mass, leading to an empirical formula of C5H6O3. To determine the molecular formula, the number of carbon atoms in 1.23 g of reductic acid is calculated and compared to the given 3.25x10^22 atoms of carbon. The ratio derived from these values helps to identify the molecular formula. Finally, the mass of one molecule of reductic acid can be calculated using Avogadro's number. The discussion focuses on the calculations necessary to derive the molecular formula and the mass of a single molecule.
Oblivion77
Reductic acid contains 52.63% carbon, 5.30% hydrogen and 42.07% oxygen by mass.
a) Determine the empirical formula of reductic acid
b) If 1.23 g of reductic acid contains 3.25x10^22 atoms of carbon, what is the molecular formula of reductic acid ?
c) Calculate the mass of one molecule of reductic acid.
I already found that the empirical formula and found that to be C5H6O3. But I can't seem to get the other parts. Thanks for the help.
Use the molecular mass of the empirical formula to find the number of carbon atoms that there would be in 1.23 g and then compare this to the actual number of carbons given in the problem
e.g.
1.23 g ( moles / g = MW of C5H6O3 ) = moles of C5H6O3
convert this to atoms of C5H6O3 and then this to atoms of Carbon = x
3.25 X 10 ^ 22 atoms of carbon / x = the number factor to multiply your empirical formula to find the molecular formula.
For the next part simply use Avogadro's number.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
14K
