Endurance & maximum range speeds
  • Thread starter Thread starter NTW
    Maximum Range
Maximum endurance and maximum range speeds are related by the factor 3^0.25, but a clear derivation is sought. A provided MIT article addresses the origin of this relationship. However, the discussion highlights that the dynamics can vary between power-producing and thrust-producing powerplants. Additionally, real-world applications of these principles are more complex than theoretical models suggest. Understanding these nuances is essential for accurate analysis in aviation contexts.
NTW
Hello all...
I know that it can be derived, from first principles, that maximum endurance and maximum range speeds are related by the factor 3^0,25.
But I haven't been able to find a derivation. Could anyone here help...?
Thanks in advance...
I think it's different for power-producing and thrust-producing powerplants.
The link answers the OP's question about where the "magic number" came from.
But nothing about aircraft is that simple in real life.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
