Energy and basic math (proportionality)
In a race scenario where a runner must carry a mass equal to her own, the relationship between her speed and the mass is analyzed using the kinetic energy formula E=1/2mv². When the mass is doubled, the equation indicates that the speed squared (v²) is halved, leading to a new speed (v₁) that is the square root of half the original speed (v₀). This results in a speed change factor of approximately 0.71, as derived from the equation v₁² = (1/2)v₀². The discussion clarifies the mathematical steps needed to arrive at this conclusion, emphasizing the importance of understanding proportionality in physics. Ultimately, the correct speed factor is confirmed to be 0.71.
Natko
A person running in a race has to pick up a mass equal to her own mass. Assuming she can still do the same
amount of work, her speed will be changed by a factor of
a. 0.25
b. 0.50
c. 0.71
d. 1
e. 2
E=1/2mv2
Since m is doubled, v2 should be halved. I'm stuck now. But the correct answer is 0.71. Can someone explain how?
a. 0.25
b. 0.50
c. 0.71
d. 1
e. 2
E=1/2mv2
You're correct that ##v^2## should be halved (multiplied by a factor of 1/2). So what does that say about the factor by which ##v## should be decreased?
Well, 1/2 squared is 0.25, and 12 halved is 0.5. How do I get to 0.71?
You know that her initial kinetic energy is ##\frac{1}{2}mv_{0}^2##, the final kinetic energy is ##\frac{1}{2}(2m)v_{1}^2##.
You need to find what the relationship between v1 and v0 is. Ask yourself, how can you do so given the above equations?
v12 = ((1/2)v0)2
If I let v0 = 1, then v1 = sqrt(1/2), which equals 0.71 :)
Natko said:
v12 = (1/2)v02
If I let v0 = 1, then v1 = 1/2, which doesn't work out.
That's not true. Check your math. As you state above, you've simplified the equation to the following:
##v_{1}^2=\frac{1}{2}v_{0}^2##
So just take the square root of both sides. What does that get you?
Changed my previous post. Thanks!
