sgstudent said:
Also I'm unsure about questions where they ask to 'stop a moving object' if the object has a certain amount if kinetic energy at that point, then to stop it I need an work done by brakes which is the same. But if I simply have a force to stop it will it stop?
It depends on if the force does work and how it does work.
To picture my example clearly, imagine a small plane which going both up and towards right (lets say at an angle 45 degrees with horizontal)(imagine gravity free space )
Let its mass be 2kg and its velocity in y direction be 2m/s and in x be 2m/s (its moving at 45 degrees).
Its kinetic energy total is 8J ,
(4J due to movement in y and 4J due to movement in x.Although we never assosciate energy with direction, i am stating this ti make my example clear)
Now suppose you apply a force with your hand in negative y direction
The max (negative) amount of work this force can do is -4J.
By doing work of -4J this force brings the plane to halt in y direction.
Any further work done by this force will result in positive work now because the displacement in -y direction will be parallel to this force.
To stop the body completely you will have to apply a force along x direction as well and do a work of -4 J.
Also you were talking of a car traveling and you applying a force to stop it.
At this point the car has positive velocity.
Its velocity can be brought to 0 only when you decelerate it in oppsing direction with a force.(which is what we saw by the energy explanation that a force has to act opposite to velocity vector(remember velocity vector is always parallel ti displacement vector) to stop it.any force in perpendicular direction will be of no use as this won't cause a deceleration nor will it be capable of taking away all kinetic energy of the body.
In essence the kinematics and energy descriptions are one and the same and are just two different ways to see a physical situation.
Using one over the other is simply a matter of convenience.
