Energy conservation .... contradiction?
The discussion revolves around the conservation of energy and momentum in a system involving a mass m connected by a tension force T, particularly in two cases of motion: one where the mass moves in a circular path and another where it interacts with a post. Participants explore the implications of tension on work, energy conservation, and the behavior of momentum in these scenarios.
  • Some participants argue that since the force T is perpendicular to the trajectory of mass m, the translational mechanical energy is conserved, suggesting that the initial speed equals the final speed.
  • Others challenge the assertion that linear momentum remains constant, noting that momentum is a vector quantity and can change without its magnitude changing.
  • One participant proposes that in case (a), the tension T does not perform any torque on the ball, thus conserving angular momentum, while another suggests that in case (b), the tension does produce torque, complicating the conservation of angular momentum.
  • There is a discussion about the radial direction of the ball's motion and how it relates to the work done by the tension force, with some participants asserting that the object is not making progress parallel to the cord.
  • Participants explore the implications of the pipe rotating about its axis and how this affects the energy transfer to or from the ball, questioning whether the ball can maintain a fixed rotation rate.
  • Some participants express confusion about the definitions of tangential and radial directions in the context of the problem, leading to further clarification on the initial velocity directions in both cases.
Participants express multiple competing views regarding the conservation of energy and momentum, particularly in the context of the tension force and its effects on the system. The discussion remains unresolved with no consensus on several key points.
Participants note that the problem's complexity increases with the introduction of rotational motion and the varying definitions of direction, which may affect the conservation laws being discussed.
madafo3435
In b). Since the force T is perpendicular to the trajectory of the mass m, T does not perform any work on m, therefore the translational mechanical energy is conserved, from which I deduce that the initial speed is equal to the final speed, moreover, the speed is constant.
Now, when analyzing the linear momentum, due to the force on m T, it can be deduced that when evaluating the integral of this force in time, it gives different from 0, but since the speed of the mass m remains constant as well as its mass, its linear momentum must remain constant, so the previous integral would be equal to 0 ... can you see this possible contradiction?
I am right?
\begin{equation*}
\int T(t)\,\mathrm{d}t=0?
\end{equation*}
This is incorrect. Momentum is a vector quantity. It can change without its magnitude changing.
Thank you so much! i have overlooked it
If the radial distance of the ball to the post is reduced, and it does since eventually it hits the post, that means a translation exists in radial direction.
In case (a), the tension of the string T is also in the radial direction, so this force is performing some work on the ball, because the ball has some translation also in the radial direction. But, since this force passes through the center of the post, it can not perform any torque on the ball, and thus the angular momentum with respect to the center of the post is a conserved quantity. If you calculate angular momentum conservation, you will reach that the magnitude of the speed v is higher for a smaller radius, thus the kinetic energy (proportional to v^2) has increased. The energy for this increase is provided by the work performed by the force T. (T is not constant, though, for smaller radius it also increases) Please note that, even though T is in the radial direction, the speed of the ball is not always perpendicular to this force, because in order to reduce the radius, it needs some component of the speed in the radial direction. You can imagine the trajectory of the ball as some kind of spiral. Then, the radial force T is not exactly perpendicular to the trajectory, and this is why the magnitude of the speed of the ball increases. However, the final speed of the ball, since angular momentum is conserved, does not depend on the specific trajectory the ball follows.
In case (b), the tension T is also not exactly perpendicular to the speed of the ball, but it's more clear now since the size of the post R is finite. According to the drawing, there's a component of T that is opposite to the speed direction. Also, now T does not pass through the center of the post, so the angular momentum is not conserved any more, this is, a torque is produced by T in the system. The calculation of the final speed looks harder in this case.
It is exactly perpendicular to the velocity of the ball and the kinetic energy is conserved
Then, angular momentum is not conserved? How can the radius change if the speed is never in radial direction? If the energy is conserved, what happens with the work done by T?
if you mean the angular momentum about the axis of the cylinder then yes, it is not conserved
this work is equal to zero
Sorry, I thougth it was case (a). My bad. How can you prove that in case (b) the kinetic energy is conserved?
I calculated the velocity and made sure that it is perpendicular to the rope
Can I see the calculation?
We are in case b here with the cord wrapping around the pipe. I will assume that by "radial direction" you mean the direction toward the center of the pipe. Importantly, this is not the same as the direction along the cord.
The object is moving at right angles to the cord. It is not moving at right angles to the radial direction. It is making progress in the radial direction.
You ask about the work done by T. What work done by T? The object is not making progress parallel to the cord. It is making progress parallel to the radial direction. They are not the same thing.
I thought it was case (a), sorry.
The problem becomes interesting if in the case (b) the pipe rotates about its axis with given angular velocity ##\omega=const## and the question is will the ball reach the pipe or not?
I was confused on what the statement of the problem meant by "tangentially". At first I thought it meant perpendicular to a line from the center of the post to the ball, but I guess it really meant simply perpendicular to the string. Because in case (b) the velocity of the ball is constrained by the string so it can not have a component parallel to the string pointing outside, so the initial velocity couldn't have been as what at first I understood as "tangentially"...
So in the two cases the initial velocity have a slightly different direction, which is not so good for comparative purposes...
Yes, a slight ugliness to the problem. But negligible as long as r is large compared to R.
If ##\omega=v_0/r##, then the ball should rotate at a fixed distance ##r## with the string not wrapping nor unwrapping around the post, right?
If the post is rotating then the cord will be moving in the direction of its length. This results in a transfer of energy to or from the ball. One could write down a formula for the rate of transfer. The ball cannot maintain a fixed rotation rate if it is speeding up or slowing down at a fixed distance from the post.
The Lagrangian is
$$L(l,\dot l)=\frac{m}{2}\Big(l^2\omega^2+\frac{l^2}{r^2}\Big(\frac{dl}{dt}\Big)^2\Big)$$
Yes sir, that is true, but in this problem that does not happen. Even so, due to the conservation of kinetic energy, it is not necessary to analyze the behavior of mass m during its anneal to find its final speed. I think the essence of this problem is to analyze what quantities are conserved and to use this powerful tool to avoid complex developments.
Try to draw a phase portrait of the system in the plane ##(l,\dot l)##.(See #19) You will be surprised I promise
wrobel said:
The Lagrangian is
What's the procedure to get to that lagrangian?
To calculate the kinetic energy of the ball as a function of ##l,\dot l##.
I know but I couldn't reach that expression...
Very clear. Thank you.
This problem admits an energy type first integral:
  • · Replies 30 ·
  • · Replies 53 ·
