What is the energy density of sunlight on Earth and near the surface of the sun?
theinfojunkie
[SOLVED] Energy Density of Sunlight
Use the solar constant (1350 W/m^2) to calculate the energy density of sunlight at a)Earth and b) near the surface of the sun.
Stefan-Boltzman = (2pi^5)/(15(h^3)(c^2))
h=6.63x10^-34 j.s
L(solar luminosity)=4pi(D^2)S
S=1340 W/m^2
I don't know what I'm doing. I'm assuming those are the more important things to use.
I'm getting frustrated with this and really need some help. I'm trying to plug in the power per area into the stefan boltzman eq to see if I can find the answer but it isn't working.
Thought about it some...
Could I use Planks formula or Raleight Jeanes law to solve this? Since the wavelength is rather large, I'm thinking I could, but I'm not sure how to apply it.
dR/D(lambda)=dU/d(lambda)(4/c)
du=4dR/c
integrate
u=4R/c
where R is 1350(solar constant) and gives the energy density on earth.
for part b
L=4pir^2 S(solar constant)
S=L(luminosity)/4pir(of the sun)^2
then u=4r/c where R=S
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
