Can Electricity Alone Convert Energy into Matter Like in Star Trek?
  • Thread starter Thread starter 04qWIGk3
    Energy Matter
Electricity alone cannot convert energy into matter as depicted in Star Trek, since electrons cannot transform into protons and neutrons, which are composed of quarks. For such a conversion to occur, a reservoir of protons, neutrons, and electrons would be necessary. Solar panels do not create new electrons; instead, they cause existing electrons to move, generating electric current. The process of converting an electron directly into energy is impossible due to the conservation of lepton number and charge. Overall, while the concept of energy-to-matter conversion is intriguing, it remains firmly in the realm of science fiction.
04qWIGk3
From my understanding it's impossible for electrons to directly turn themselves into neutrons and protons. Electrons are an elementary particle while neutrons and protons are made from elementary particles (quarks).
Questions:
1# So 'energy into matter' replicator like star trek are impossible using only electricity (electrons) right? For this to work you would need a 'reservoir' of protons, neutrons and electron?
2# Do solar panels create electrons or do they simply cause the ones that exist to move around? Seems if they create a hole/electron pair, then a massless photon created a massive particle?
You can't convert electrons alone directly into energy. One way to understand this is conservation of certain kinds of particle number. For example, lepton number is typically conserved, and the electron has lepton number 1, while a photon ("pure energy") has lepton number 0. So the process electron-->photon doesn't conserve lepton number and is therefore impossible. Moreover, that process doesn't conserve charge. To get an electron to turn directly into energy, you could combine it with a positron, the electron's antiparticle. Particle-antiparticle fusion always conserves quantum numbers, and can yield just a photon (or multiple photons) as a result.
Solar cells just propel the electrons around. The same is true of batteries and the electrical generators at power plants.
1: Yes, it's still a great sci-fi. We do not know how such replicator would work.
2: The electrons are in the panel already, the radiation just makes them move systematically and form electric current.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
