Energy, Mass, Speed of Light: Can We Reach It?
In summary, the conversation discusses the concept of traveling at nearly the speed of light in a spaceship and whether the spaceship would slow down on its own or if it would require a constant input of energy to maintain its speed. It is concluded that according to Newton's first law, the spaceship would continue to move at a constant speed even without the application of energy. The idea of reaching the speed of light is also discussed, with the understanding that it would require infinite energy, which is not possible. The conversation also addresses the idea of using an infinite energy baseball bat to keep an object moving at the speed of light. It is clarified that while the object would continue to move at a high speed, it would not be able to reach the speed of
LawH
TL;DR Summary
I am not a physics student of any kind, but not knowing the answer to this has bothered me for some time
Hello everyone!
Let's say that you were to attempt to go as fast as possible on a spaceship with the mass of an average car in an absolute perfect vacuum. What I am wondering is, that if you were to reach a certain speed, and stop applying energy to this imagined spaceship, would the spaceship start slowing down by itself?
What I want to understand is, that reaching the speed of light in this spaceship would be impossible, because it would require a jolt of infinite energy, or that to keep it going at the speed of light, it would require a constant infinite input of energy to the spaceships movement to keep it moving? If you were to travel close to the speed of light in this spaceship, would you have to keep applying energy to it's movement, even if you had reached the speed that you wished to travel into keep it going, or, if you would get your ship to travel a certain speed, it would remain traveling at this speed and the problem is actually getting the ship to reach that speed, but once reached, the ship would carry on traveling in the speed it was pushed to travel in?
I hope you understood my question, and I hope I can understand your answers! :D
At one time people believed yes, but now we know the answer is no, as per Newton's 1st law.
Likes Ibix
Let me just underline and boldface the fact that this is nothing peculiar for relativity. This was already part of classical mechanics, as formulated by Newton through the first law.
Likes vanhees71, Ibix and russ_watters
Alright, so theoretically anything with mass could travel at almost the speed of light forever without any thrust applied to it after it had reached a certain speed.
This has bothered me for a while, and I wasn't sure if something other than Newtonian physics was going on at this speed, when it comes to movement. For some reason it had always been unclear to me whether reaching light speed was a problem due to the need for continued application of thrust, or whether it was actually getting to that speed. Thanks!
Likes russ_watters
Yes, I have understood the classical mechanics, but was wondering about this particular fact. Using an infinite energy baseball bat, and striking a ball with it, would keep the ball moving forever at light speed in a vacuum, so to speak.
Nigh-infinite energy in the bat. Can't have infinite energy.
The ball would keep moving (effectively) forever at nearly the speed of light. Can't reach c.
First of all, you have to say what it's moving with respect to. As I sit here and type this I'm moving at near light speed relative to an electron in a particle accelerator. There is no experiment that you can do, even in principle, that will distinguish between a state of rest and a state of uniform motion. So, no, your spaceship will not start slowing down, relative to, say, planet Earth, when you shut the engines off.
There's no such thing as infinite energy. What that trite comment means is the following. Starting with the postulate that the speed of a beam of light in a vacuum is ##c## relative to you, regardless of how fast you chase after it, you can conclude that no matter how fast you move you will never catch it. Thus you can never reach a speed of ##c##. You don't need to look at the concept of energy to reach that conclusion.
But if you throw in as another postulate the notion I described above in my first paragraph, you can come up with a relation between the energy of a particle and its speed. As that speed approaches ##c## the energy increases beyond all bounds. Or using the jargon, the energy approaches infinity.
Likes Ibix and Rolacycle
There is no infinite energy baseball bat I think we can all agree on that. But this particular question is answered now I feel, and I can move on to understanding how it's possible that light travels at the speed of light regardless of the observers' relative speed to each other and light.
Yes, that's a more interesting question.
Just to reiterate something @Mister T said - you cannot talk about speed without saying what it is you are regarding as stationary. This is part of the "principle of relativity", which says that all physical laws take the same form in all inertial frames of reference. This tells you immediately that you won't start slowing down above a certain speed, because that would apply to everybody. You'd have to start speeding up so that someone moving past you sees you slowing down from their reference frame, and two people moving past you in opposite directions would need you to speed up in both directions at the same time in order for you to be slowing down according to both of them. This is obviously inconsistent. As others have noted, the principle of relativity has been a feature of physics since Galileo and no violation of it has ever been detected.
Regarding the invariance of the speed of light, that is also a postulate. That is, it is something for which the only answer to "why" is "because physical models make accurate predictions when we assume that". Investigating how this can be consistent is essentially "learning special relativity". It doesn't require maths any more complicated than Pythagoras' Theorem, but letting go of the notion of a single universal notion of time does seem to give people trouble.
What is energy and how is it related to mass and the speed of light?
Energy is a fundamental property of matter and can be defined as the ability to do work. It is related to mass through Einstein's famous equation, E=mc^2, which states that mass and energy are equivalent and can be converted into one another. The speed of light, c, is a constant that represents the maximum speed at which energy and information can travel in the universe.
Can we ever reach the speed of light?
According to the theory of relativity, the speed of light is the maximum speed at which any object can travel. As an object approaches the speed of light, its mass increases and it requires an infinite amount of energy to accelerate it further. Therefore, it is not possible for any object with mass to reach the speed of light.
What is the significance of reaching the speed of light?
Reaching the speed of light is significant because it would require an infinite amount of energy and would result in infinite mass. It also has implications for time dilation and the distortion of space, as predicted by the theory of relativity. Additionally, it would allow us to travel vast distances in the universe in a relatively short amount of time.
Are there any particles that can travel at the speed of light?
Yes, particles with zero mass, such as photons, can travel at the speed of light. This is because they do not have any mass to increase as they approach the speed of light. Photons are the fundamental particles of light and are responsible for carrying electromagnetic energy.
What are some current technologies that utilize the principles of energy, mass, and the speed of light?
Some current technologies that utilize these principles include nuclear power plants, which convert the energy from nuclear reactions into electricity, and particle accelerators, which use electromagnetic fields to accelerate particles to near the speed of light for research purposes. Additionally, GPS systems rely on the principles of relativity to accurately measure time and distance for navigation.
