kev said:I'm assuming that \Sigma (E^2-p^2c^2) IS invariant.
1effect said:True but the above expression doesm't represent anything meaningful.
The energy of a particle system is \Sigma E and the resultant momentum is \Sigma \vec{p}. Neverheless, you can't make a 4-vector out of (\Sigma E,c \Sigma \vec{p}). Bummer.
kev said:So if I sum the energies of all the individual particles in a system that does not represent the total energy of the system?
kev said:So the sum the energies of all the individual particles in a system does not represent the total energy of the system?
... and the sum of the individual momentums of all the individual particles in a system does not represent the total momentum of the system?
1effect said:Were you summing the energies? Where? In what formula?
kev said:It's hypothetical. For example how can you be sure of the total mass of a system of particles, without knowing the exact velocity of evry particle in the system?
kev said:I am trying to figure out the significance of (\Sigma E)^2-c^2(\Sigma \vec{p})^2
Where do we use it? Why do we need it? It's related to a problem I am working on and so I really am interested.
You have neglected to state under what circumstances that is true. If the system is a closed system and you're speaking about the total energy E and the total momentum P of the system (including the energy and momentum of fields if present) then, in general, the quantity E^2-c^2(\vec{p})^2 will be invariant.1effect said:...for a point particle is a 4-vector. Consequence : E^2-c^2(\vec{p})^2 is an invariant
Nevertheless, for a system of particles, the energy momentum is not a 4-vector. See here.
The second expression is standard, and in most textbooks. It is called the "invariant mass squared" of a collection of free particles, and has been used to find most of the resonances in the PDG. I don't have to look at a website that denies it.1effect said:
Note that the reason why it makes sense to consider \Sigma E and \Sigma \textbf{p} is because of conservation of energy and momentum. We want to replace our multi-particle system with a single particle which behaves like the system, as far as possible.1effect said:...for a point particle is a 4-vector. Consequence : E^2-c^2(\vec{p})^2 is an invariant
Well the above seems to suggest it is invariant in the case of a "closed finite" system. The only reason for it not being invariant would be if the summation is over different particle 4-vectors for different observers. A sum of 4-vectors is always a 4-vector, and so its "length" is invariant.1effect said:Hence (\Sigma E)^2-c^2(\Sigma \vec{p})^2 is not an invariant. See here
In those circumstances where the total 4-vector \left(\Sigma E, \Sigma \textbf{p}c \right) is well defined (a "closed finite" system, see my last post), it represents (Mc^2)^2, where M is the invariant mass ("rest mass") of the whole system.kev #8 said:I am trying to figure out the significance of (\Sigma E)^2-c^2(\Sigma \vec{p})^2
Neither (\Sigma E)^2-c^2(\Sigma \textbf{p})^2 nor \Sigma(E^2-||\textbf{p}||^2c^2) are 4-vectors. They are scalars. But the first is a square-norm of a 4-vector (proportional to square mass), and the second is a sum of square-norms of 4-vectors (proportional to a sum of square masses).kev said:OK, for what it's worth I think it is fairly easy to show that (\Sigma E)^2-c^2(\Sigma \vec{p})^2 is not invariant even for the simple case of two particles with parallel motion and different velocities.
(\Sigma E)^2-c^2(\Sigma \vec{p})^2 is not a four vector and does not work to obtain a value for the invariant mass of the system, while \Sigma(E^2-p^2c^2) is a four vector and does work. Why use something that doesn't work?
I disagree most emphatically. The above expression is the mass of the system, or (if you prefer) the rest energy of the system. Not only is it frame invariant but it is conserved. I cannot think of a more useful physical concept than something that is both frame invariant and conserved.1effect said:True but the above expression doesm't represent anything meaningful.kev said:I'm assuming that \Sigma (E^2-p^2c^2) IS invariant.
DrGreg said:Note that the reason why it makes sense to consider \Sigma E and \Sigma \textbf{p} is because of conservation of energy and momentum. We want to replace our multi-particle system with a single particle which behaves like the system, as far as possible.
For each particle, the four dimensional vector \left(E, \textbf{p}c \right) is a "4-vector", which means that it obeys the Lorentz transform
E' = \gamma_u \left(E - u p_x \right)
p_x' = \gamma_u \left(p_x - \frac{u E}{c^2} \right)
p_y' = p_y
p_z' = p_z
The question is, is \left(\Sigma E, \Sigma \textbf{p}c \right) a 4-vector, i.e. does it also obey the Lorentz transform? You might think the answer is "yes", but we have to ask, what does \Sigma E really mean? It tells us what to sum, but it doesn't say when to measure all the individual energies. In Newtonian theory, we measure them simultaneously. But in relativity, "simultaneity" is a frame-dependent concept. Sure, you can add up all the 4-momenta simultaneously relative to some observer and get a 4-vector, but if you add up all the 4-momenta simultaneously relative to another observer you might get a different 4-vector (because you are adding a different set of 4-vectors).
DaleSpam said:I disagree most emphatically. The above expression is the mass of the system, or (if you prefer) the rest energy of the system. Not only is it frame invariant but it is conserved. I cannot think of a more useful physical concept than something that is both frame invariant and conserved.
DrGreg said:In those circumstances where the total 4-vector \left(\Sigma E, \Sigma \textbf{p}c \right) is well defined (a "closed finite" system, see my last post), it represents (Mc^2)^2, where M is the invariant mass ("rest mass") of the whole system.
I made no assumptions here about the relative directions of u and p. u does not align with the momentum, it is the relative velocity between an arbitary pair of frames. All I've done is align the spatial-coordinate system with u. So, for a given pair of aligned frames, the equations I quoted here are valid for all particles. (You can work with the unaligned version of the Lorentz transform if you wish, but there's no need.)1effect said:You can't use the above transformation in the case of a multiparticle system because you can't arrange for u to align with more than one momentum (if they all have different directions).In other words, you need the generic transformation , the one that changes bot p_y and p_z.
The sums of squares of the invariant masses of the particles is indeed invariant. It is conserved if the particles never merge or decay, but not otherwise. But it definitely is not the square of the system's invariant mass, which is (for a closed system) proportional to (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2.DaleSpam said:I disagree most emphatically. The above expression is the mass of the system, or (if you prefer) the rest energy of the system. Not only is it frame invariant but it is conserved. I cannot think of a more useful physical concept than something that is both frame invariant and conserved.1effect said:True but the above expression doesm't represent anything meaningful.kev said:I'm assuming that \Sigma (E^2-p^2c^2) IS invariant.
I'm quoting this paper as I said in this post, where I gave my interpretation, but I'm not 100% sure. I believe that "closed" means your particles cannot be interacting with anything outside the system (it doesn't mean they have to be "sealed in a box").kev said:First, can you define a "closed finite" system?
DrGreg said:I'm quoting this paper as I said in this post, where I gave my interpretation, but I'm not 100% sure. I believe that "closed" means your particles cannot be interacting with anything outside the system (it doesn't mean they have to be "sealed in a box").
Your calculations with (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2 are confirming that it does represent invariant-mass-squared (rescaled into square-energy units), in the circumstances you have tested. Of course, in the centre-of-mass frame, invariant mass is the same as "relativistic mass", i.e. \Sigma E / c^2.
Ich said:There is no doubt that the invariance holds, as pam said, this is a standard approach.
The particles might even interfere with a wall or something, as long as this wall is included in the sum. You may even let the particles disintegrate or create new particles from kinetic energy in a collision, it is exactly this expression that is always conserved. The rest mass of the system.
Show it.kev said:I can show a closed system where (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2 is NOT invariant.
The second one is energy, not rest mass. It's difficult enough when people confuse different meanings of "mass", don't introduce a second meaning of "rest mass".Also bear in mind that we have two distinct definitions of rest mass being used in this thread.
1) m_oc^2
2) {m_oc^2 \over \sqrt{1-v^2/c^2}}
Definition 2 is not invariant.\Sigma (E^2-c^2||\textbf{p}||^2) has definition 1 as the invariant quantity and
(\Sigma E)^2-c^2||\Sigma \textbf{p}||^2 has definition 2 as the invariant quantity which includes the thermal kinetic energy in the centre of mass rest frame as part of the rest mass.
Are you sure about that? That goes against what I understood about the conservation of the 4-momentum (of course I am not a physicist). I understood that the sum of the 4-momenta was conserved even across particle decay.DrGreg said:The sums of squares of the invariant masses of the particles is indeed invariant. It is conserved if the particles never merge or decay, but not otherwise. But it definitely is not the square of the system's invariant mass, which is (for a closed system) proportional to (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2.
kev said:Also bear in mind that we have two distinct definitions of rest mass being used in this thread.
1) m_oc^2
Ich said:The second one is energy, not rest mass. It's difficult enough when people confuse different meanings of "mass", don't introduce a second meaning of "rest mass".
kev said:\Sigma (E^2-c^2||\textbf{p}||^2) has definition 1 as the invariant quantity and
Ich said:Definition 2 is not invariant.
The first equation is the sum of the rest masses of the constituends. A sum of scalars, invariant, but not conserved.
The second equation is the norm of a sum of four vectors, also a scalar, and the definition of the rest mass of a system. Invariant and always conserved.
In flat spacetime, of course.
Ich said:Show it.
DrGreg said:I made no assumptions here about the relative directions of u and p. u does not align with the momentum, it is the relative velocity between an arbitary pair of frames. All I've done is align the spatial-coordinate system with u. So, for a given pair of aligned frames, the equations I quoted here are valid for all particles. (You can work with the unaligned version of the Lorentz transform if you wish, but there's no need.)
1effect said:You did (unknowingly). By using the transforms that affect only p_x and leave p_y and p_z unchanged.
I believe that kev just posted something that proves that (\Sigma E)^2-c^2(\Sigma\vec{p})^2 is not an invariant via a counterexample.
For quite a while I have pointed out that ,in the case of two particles E_1E_2-c^2 \vec{p_1} \vec{p_2} is not an invariant.
kev said:so if I have calculated correctly <br /> (\Sigma E)^2-||\Sigma \textbf{p}||^2<br /> is not invariant for particles in a box.
Ich said:The particles might even interfere with a wall or something, as long as this wall is included in the sum.
kev said:Dr Greg is right that the y and z components of momentum do not change under transformation if the frame is moving in the x direction and it is correct mathematically and convenient to align one axis of the momentum components with the motion. Doing it any other way is just making life hard for yourself.
p_x ' = {m_o (v+u_x)\over \sqrt{1-u_x^2}\sqrt{1-v^2}} = { p_x\over \sqrt{1-v^2}}+{m_o v\over \sqrt{1-u_x^2}\sqrt{1-v^2}}
p_y ' = {m_o u_y\sqrt{1-v^2}\over \sqrt{1-u_y^2}\sqrt{1-v^2}} = p_y
p_z ' = {m_o u_z\sqrt{1-v^2}\over \sqrt{1-u_z^2}\sqrt{1-v^2}} = p_z
Where u_x, u_y, u_y are the velocity components of the particles in the centre of mass rest frame S.
It seems that it is fair to say that (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2 is invariant most of the time, but care is required in its use. .
1effect said:You seem to be missing the point. While you can surely align u with the momentum of one particle, all the other momenta will not be necessarily aligned with u.
kev said:The point is that you split the momentum of each particle into x,y, and z components and then transform just the x component of each particle.
1effect said:This is also incorrect. You can easily try it for 2 particles , take \vec{v_1}=-\vec{v_2} and look at E_1E_2-\vec{p_1} \vec{p_2}
You will quickly see that the expression is not invariant.
kev said:When \vec{v_1}=-\vec{v_2} the term \vec{p_1} \vec{p_2} is zero
1effect said:I don't think this one is right :\vec{p_1} \vec{p_2}=-\gamma^2 m_1m_2v_1^2
kev said:Oops. Your right. I was talking about (\Sigma E)^2-c^2||\Sigma \textbf{p}||^2
where ||\Sigma \textbf{p}||^2 goes to zero, because the momenta are summed before they are squared. [p_1 + (-p_1)]^2 = 0
1effect said:I don't think this is right either, we were taliking about a system of two particles , so \vec{p_1}+\vec{p_2}=\gamma (m_1-m_2) \vec{v_1}.
kev said:If m_1 = m_2 then \vec{p_1}+\vec{p_2}=\gamma (m_1-m_2) \vec{v_1} =0
jtbell said:The quantity of interest here is
(m_0 c^2)^2 = E^2 - (pc)^2 = E^2 - (p_x c)^2 - (p_y c)^2 - (p_z c)^2
A Lorentz boost along the x-direction leaves p_y and p_z invariant. Therefore it suffices in this case to show that E^2 - (p_x c)^2 is invariant.
1effect said:...
kev said:...
Also remember that by definition the total momentum in the centre of mass rest frame is zero so if u_1 = -u_2 then m_1 must equal m_2.
1effect said:There was no specification of any "equal masses" anywhere. This is a system of arbitrary particles.
kev said:You did specify \vec{v_1}=-\vec{v_2} so as I said in my last post that specifies equal masses by definition because the total momentum in the rest frame of the particle system is zero by definition.
1effect said:Why is so difficult for you to accept when you make a mistake?
p_y ' = {m_o u_y\sqrt{1-v^2}\over \sqrt{1-u_y^2}\sqrt{1-v^2}} = p_yp_z ' = {m_o u_z\sqrt{1-v^2}\over \sqrt{1-u_z^2}\sqrt{1-v^2}} = p_z
