Energy of a system-two colliding balls
  • Thread starter Thread starter haha1234
    Balls Energy
To estimate the kinetic energy of the two colliding steel balls, first determine their mass using the density of steel and the volume calculated from their diameter of 25.4 mm. The density of steel can be referenced from standard tables, as it varies by alloy. Once the mass is found, apply the kinetic energy formula, KE = 0.5 * m * v^2, using the velocity of 5 m/s for each ball. The details about Hooke's law and the vise experiment are likely relevant for later parts of the problem but are not needed for this kinetic energy calculation.
haha1234
Two identical steel balls,each of diameter 25.4mm and moving in opposite directions at 5m/s,run into each other head-on and bounce apart.Prior to the collision,one of the balls is squeezed in a vise while precise measurements are made of the resulting amount of compression.The results show that Hooke's law is a fair model of the ball's elastic behaviour.For one datum,a force of 16kN exerted by each jaw of the vise results in a 0.2mm reduction in the diameter.The diameter returns to its original value when the force is removed.
Compute an estimate for the kinetic energy of each of the balls before they collide.
The mass of the two balls are not mentioned in the question,so how to find the kinetic energy?
I think the key is the problem statement mentioned that the balls are made of steel. You can look up the density of steel. (The density of steel varies depending on the alloying constituents, but I'm guessing the problem is only asking for a rough estimate. Maybe your textbook has a table in it for metal densities that you can use?) Multiply that times the volume of each ball to get the mass of each ball. (Note: when calculating the volume of each ball, don't forget that 25.4 mm is the diameter, not the radius. :wink:)
Don't worry about the Hooke's law and the vise experiment for the this part. I'm guessing that information is to be used in a latter part of the problem (not mentioned here).
That's my guess anyway.
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
