B Energy of Ideal Gas: Internal E & Kinetic E
The discussion centers on the calculation of internal energy for an ideal gas, specifically questioning the exclusion of electrostatic energy in the kinetic energy formula K.E = 3/2 n R T. It emphasizes that this formula applies only to monatomic gases and does not account for potential energy or interactions in diatomic or polyatomic gases. The analogy to snooker balls illustrates that, in the ideal gas model, particles are treated as non-interacting entities. The limitations of the model are acknowledged, particularly under conditions of high pressure and low temperature. Overall, while the ideal gas approximation is useful, it has significant constraints that must be recognized.
Bhope69199
Hi,
When calculating the energy of an ideal gas we neglect the potential energy and calculate the kinetic energy using:
K.E = 3 /2 n R T
My question is why do we not consider the electrostatic energy of the gas?
If I am trying to work out the internal energy of 1 mol of Radon, why do I only require the kinetic energy and not the energy that was required to bring the electrons and protons together? Is this energy not held within the gas?
That's the meaning of ideal gas, a gas whose particles don't interact with each other. Its an approximation! Of course you can consider interactions and have a more precise model, but that means you should do harder calculations.
If your gas is so hot that electrons can be removed from atoms (=your gas is actual a plasma), you cannot approximate it as ideal gas any more.
Bhope69199 said:
Hi,
K.E = 3 /2 n R T
When snooker balls collide it is not necessary to consider the "electrostatic energy" of the snooker balls..molecules are considered to be 'snooker balls' in the simple kinetic theory of gases
Bhope69199 said:
Hi,
K.E = 3 /2 n R T
Be aware that this formula is only valid for a monatomic ideal gas. It is not valid if the gas molecules have 2 or more atoms -- e.g. O2, N2, CO2, etc.
I've personally known physics teachers who were unaware of this.
Likes vanhees71
oops...should perhaps have qualified 'translational kinetic energy'
this is more or less implied among physicists when the model is based on snooker balls, as far as I know there are no diatomic snooker balls.
Such a simple model has many limitations but is surprisingly informative.
The model also breaks down at high pressures and low temperatures, I imagine most physics teachers would be aware of this or at least suspect it.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
