What is the minimum kinetic energy of a neutron in a nuclear potential well?
bharath666
1. Suppose that the potential seen by a neutron in a nucleus can be represented by a square well of width 10^(-12)cm with very high walls. What is minimum KE of the neutron in this potential ?
2. K.E = (1/2)mv^2
3. Its an isolated system, so it drops into its lowest energy state and the energy of the lowest state is higher than the minimum of potential energy. How to calculate the minimum potential energy with the width of well ? What to do with the width of well ?
I think you are supposed to estimate it using the Heisenberg uncertainty relation.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
