Energy: Real Thing - Different Forms & Mass as Dense Concentration
  • Thread starter anantchowdhary
In summary, energy can be defined as the ability for a force to do work. The different forms of energy arise due to the variety of different forces, such as mechanical, electrical, thermal, etc. When mass is converted to energy through processes like nuclear reactions, there are other particles involved to maintain the conservation of charge, spin, and momentum. Therefore, the idea that mass is simply a concentration of energy is not entirely accurate. Additionally, focusing light to create a strong gravitational field has not been observed and is not supported by current theories.
anantchowdhary
372
What exactly makes forms of energy different from each other?
Can we say that mass is a dense concentration of energy?o:)
Hey pls sum1 answer this
Energy is in some way the same as mass yes. I believe it 'connects' the elementary point(0-dimensional) particles to each other, making particles like protons, and neutrons. And it also connects them to each other making atoms, and molecules.
It has the effect of increasing the mass of the object. Well, I don't know if this is 100% correct, but no one else is answering...
Energy can be defined as the abilty for a force to do work. So, the different forms of energy arise due to the variety of different forces.
Hey ppl i greaatly appreciate ur views.So i gues we CAN say mass is concentration of energy.So now i hav another doubt,Why are forms of energy different?
Different forces?Forces all of em hav the same effects!
For those of you who think that mass can be defined as nothing more than "concentrated energy", consider the following:
Take an example of "pure" energy such as photons. Now clump them all very tightly to form as mass per the scenerio of the OP. Now explain to me the following:
1. photons have no charge, yet, electron, quarks, etc... all do. Where do these charges come from?
2. Photons have spin of 1. elementary fermions have spins of 1/2. How do you get the basic projection of the "units" of 1 to get spin of 1/2?
3. Photons do not interact via the weak interaction (they don't, at this point, participate in strong interactions either, but in some postulated theory, they might in higher order interactions). Yet, we know many particles that do. Where did that come from?
Zz.
Hi ZapperZ,
see first of all u cannot clump energy in motion(photons CANNNNOT exist at rest).And hence the energy together won't hav spin.So this situation is INVALID SIR!
and ZapperZ,When mass is "converted" to energy on nuclear reactions(say light energy therefore photons),how does spin change suddenly?
Also ZZapperZ,light shud create gravity if focussed to such an extent that it may hav a very strong gravitational field.This is as energy has the same effects of mass!
Hi ZapperZ,
But isn't that what YOU are claiming or asking in your original question? A "photon" is what most would consider as a "pure energy". So? I was merely demonstrating what you are asking for and then I turn around and applied it to see what kind of results one would get.
So it appears that you have answered your own question.
This is because the mass just doesn't appear out of nowhere. When a photon is converted into mass via pair production, you have several things that goes on (i) the net charge is conserved because of the production of the particle and its antiparticle partner (ii) the spin is conserved because of the same reason, and (iii) momentum is conserved because such a process can only occur in the vacinity of a more massive particle to take up the missing momentum. The same in a nuclear reaction. There are other particles involved in the process. You just don't see a particle spontaneously dissolve into just pure energy all by itself with nothing else going on.
It isn't as simple as "mass is just a concentration of energy".
Zz.
Show me where this has occurred and been observed.
Zz.
and the light q sry
it SHUD occur that's wat I am saying.U cannot feel it
cant the nuclear reaction example be due to change of density of energy!IN GR dense energy curves spactime more than energy spread out
Here in the nuclear reaction case,mass is CONVERTED to energy.Im sry as i wrote energy>>mass
It doesn't matter. There is STILL a bunch of particles involved. In the matter-antimatter anhilation, you STILL need two particles to maintain the conservation. You just don't have a particle spontaneously disappear into energy with nothing else involved.
Zz.
Hey Zapper ok so HOW exactly does mass get converted into energy.From scratch pls explain
Hell if I know. I'm not the one who wants to make any speculation. Someone else might.
However, all I care about is to make sure someone point out the inconsistency with your original question. When I see a series of responses of people agreeing with that concept, then I see that something hasn't been thought through carefully.
Zz.
PLsss I am not trying to contradict u ,but only trying to learn.Please enlighten me.I shall chek in 2morow.Good nght
Zz.
i'm new
so please tell me wat do u mean by "PURE" energy like photon
Zz.
photons hav no charge i agree yet mass formed from it has charged particles.so wats the big deal. same happens wen neutron (uncharged) gives beta emission and protns both of which r charged. wat i guess(its only a guess) the overall charge is conserved.
well just a guess think its rong. forms of energy r not different from each other.eg thermal energy often referred to as heat is a kind of kinetic energy because it is partly because of the motion of atoms or molecules within a solid, liquid or gas.Similarly, radiation energy, also commonly known as light energy, is often portrayed as being carried by moving photons.
well radiation energy is not exactly due to above reasons since photons have no invariant mass and thus the energy required to accelerate them to their velocity (and thus which is associated with their motion) cannot be calculated using other kinetic equations.
i agree ENERGY HAS SAME EFFECTS OF MASS.
one example is photoelectric effect.
photon which is "PURE" energy wen strikes an electron its displaces it. the effect is same as wen an electron is hit by a mass.
so anantchowdhary is rite.
The photon is NOT converted into an electron in there, thankyouverymuch. The electron is already present in the conduction band! All that happens is that the part of the photon energy is transferred into the electron's kinetic energy. There is NO energy-mass conversion there. The "similarity" of the scattering via a "mass" is only superficial. A scattering via another mass is NOT called the photoelectric effect. The energy and momentum dependence of the emitted electron are different!
I'd suggest you re-examine your understanding of the photoelectric effect, AND, do a bit of a search on here first regarding what has been said on PF.
Since you are new, just so you know a bit more of the situation and know what you're dealing with, the "avatar" or picture you see on your left under my member name is a snapshot of a photoemission spectrum that *I* took when I did my postdoc. This is not meant to impress you, but rather to indicate that in terms of the physics and experimental aspect of the photoelectric and photoemission phenomena, I might know "a bit more" than the average person on the street.
Zz.
I'm sorry, but I find what you typed here extremely difficult to follow. Please type in WORDS. You will eventually have to do this if you have to pass your schoolwork.
The "big deal" here is that you cannot simply ignore violations of conservation laws. There are no conservation laws that are violated in a beta decay. So why did you use that as an example but yet ask me what's the big deal with me insisting that such laws must be observed?
Zz.
Wow. Zz, you seem quite worked up. "wat is", seriously, write in proper English for us, it's bad enough if the conceptual ideas are sloppy.
It is conventional to say that mass is energy, or that energy has mass. They are basically equivalent (we even have a famous equation that quantifies this). In GR it is reasonably straight-forward to see that a "box of photons" weighs more than an empty box.
Therefore, I do think it is fair to say that "matter" is a concentrated form of energy. Of course matter also has other properties, it isn't as though we can take "pure" energy and condense it into matter. ..or maybe it is, since that's basically what particle accelerators try to do, however I don't think there's really such a thing as "pure" energy, I certainly wouldn't attribute that title to the photon!
@ZAP,
Please tell me once and for all as u know much more than any average person,How is mass converted to energy?In my point of view ,say in a nuke reaction,wat happens is just the density of energy changes ,hence the form of energy given out changes.Mass is a form of energy(Remember)
Is photon purely energy?It shud having some moving mass.The mass can be attributed as a concentrated form of energy.But the mass--->0 as the density of energy of a photon is MINUTE
I think i hav been misinterpretated. What i meant was that you said that photon is pure energy packet. On hittting the already present electrons it imparts energy to them, basically displaces them. this is same as when an electron if struck by another particle say neutron. so photon / energy has same effect as mass.
  • #31
Is photon purely energy?It shud having some moving mass.The mass can be attributed as a concentrated form of energy.But the mass--->0 as the density of energy of a photon is MINUTE[/QUOT
Photons are particles which have all of their mass converted to energy.
energy of a photon = h *v
energy = mass of photon * c^2
mass of photon can be found just that all its mass is in the form of energy
  • #32
What i mean to say is that a neutron is uncharged. But it still gives rise to charged paricles. So from where do these charges come from ?
Can't a similar case happen when supposing photons are concentrated. It may be that overall charge is conserved in this case too.
  • #33
Good question. One can however only speculate about this (something which is not really appreciated in this forum, so I'll be carefull :smile: ).
Personally, I think that your idea as a concentration of energy is basically correct. Energy is normally associated with "work" which implies the product of force times distance. So, energy is normally related to things which "move". Light is a clear example of this. If you look at a proton from a distance, you don't see movement but if you go down to the quark level, things ARE in motion and at a deeper level, one could suspect that also quarks are composed of other particles - in motion. And of course, one has also all the virtual particles moving in between. So, continueing this line of argument leads to the conclusion that (probably) mass (or particle) is that thing in which energy (motional) is confined to a limited region of space. Instead of talking of conversion of mass into energy, it would be more appropriate to talk about the release of energy (from the confined region into the larger region).
  • #34
you can say that the photon has relativistic mass
  • #35
Bingo
I ENTIRELY agree with these views of yours and had the same views.only when mass is supposedly Lost or CONVERTED,it releases energy so the density of energy of the object/matter changes:smile:
  • Other Physics Topics
