Energy within an electric field
The discussion revolves around calculating the energy within an electric field generated by a sinc wave pulse between two plates. Participants explore the appropriate voltage values to use, the implications of using RMS versus peak voltage, and the integration of the sinc function to determine energy over time.
  • One participant suggests using the equation ## E= \frac{1}{2}CV^2 ## with ##V_{rms}## for energy calculations, while expressing uncertainty about its applicability to a sinc wave.
  • Another participant mentions that the integral of a sinc function is positive and questions how to account for peak voltage in integration.
  • There is a discussion about the appropriate method to calculate energy if the pulse is not a sinc wave, with references to integrating current over time.
  • Some participants propose using the peak voltage of the sinc wave to find energy in one pulse and multiplying by the number of pulses per second, but express confusion over discrepancies in results from different methods.
  • One participant emphasizes that energy in a capacitor depends on peak amplitude rather than pulse duration, drawing an analogy to mechanical systems.
  • There is a suggestion to scale the time axis for integration based on oscilloscope data, with a focus on the limits of the sinc wave integration.
  • Participants discuss the relationship between the width of the pulse and the energy delivered to the capacitor, with some confusion about how to accurately calculate total energy.
Participants do not reach a consensus on the best method for calculating energy within the electric field, with multiple competing views on the use of RMS versus peak voltage and the integration of the sinc function.
There are limitations regarding the assumptions made about the pulse shape, the definitions of voltage used, and the integration limits that remain unresolved. The discussion also reflects uncertainty about the impact of pulse width on energy calculations.
This discussion may be useful for those interested in electrical engineering, specifically in the context of pulse signals, capacitor charging, and energy calculations in electric fields.
  • #31
BvU said:
Can you explain what this means ?
What does the pulse look like ? Not like this ? :
If not, then what ? Post a picture of the scope image !
The pulse is repeating, with a set amount of time at zero voltage, so I took one wavelength. Yes the pulse is very similar to your image but not exact.
What would the scope image and schematic provide you? When you ask for frequency are you asking for pulse frequency or some other frequency, can you be more explicit?
Oscilloscope 1MΩ impedance, Scope 900MΩ impedance. Not sure of the impedance of the pulse generating device but the resistance is approx. 9kΩ.
  • #32
If I understood it right then you just have a capacitor connected to a voltage source which provides a sinc signal. In the usual quasistationary approximation the voltage at the capacitor in this case is just the voltage of the source, and the energy in the electric field within the capacitor is at all times ##E_C=C V^2(t)/2##.
  • #33
Yes your understanding is correct.
So how would I calculate the energy provided by the power source?
Would it be ##CV^2(t)##? Or would I need to find the sum of all ##CV^2(t)## over the whole pulse?
  • #34
I don't understand the question. The energy in the capacitor at any instant of time is ##C V^2(t)/2##.
Of course this scenario is unrealistic, because in reality you have a finite resistance and there's a Ohmic loss, which you can calculate by integrating the corresponding power (energy per unit time) dissipated in the resistor ##P(t)=R i^2(t)##:
$$E_{\text{diss}}=\int_{-\infty}^{\infty} \mathrm{d} t R i^2(t).$$
You can calcuate ##i(t)## by solving the differential equation of this more realistic circuit (most conveniently using a Fourier or Laplace transform).
  • #35
OK the energy in the capacitor at any instant is ##CV^2(t)/2##.
How do I find the energy supplied to the capacitor at any time, and the total energy supplied to the capacitor, if I don't know the finite resistance you mention.
  • #36
BvU said:
Bhope69199 said:
I have the oscilloscope data. I cropped the data so I have one wavelength of the pulse.
Did I miss the answer ?
Your reluctance to show the image is almost commendable.
So on the scope you almost see
Re-read post #20: ##x = \pi\ ## corresponds to t = 75 ##\mu##s, so ## a = 75 \mu s /\pi\ ## $$
10 \,\text{kV} \ \int_{-\infty}^\infty \operatorname {sinc} \left (t\over a\right ) \, dt= 0.75\,{\text Vs} $$
Bhope69199 said:
What would you like a picture of? The setup is a pulse source connected to a capacitor and the voltage drop across the capacitor is measured.
Your reluctance to show a schematic of the setup is also almost commendable.
Fortunately you dedicate a few words to it, so we can try to erverse engineer what we are talking and confusing each other about since Thursday:
So what is it ? 1MΩ or 900MΩ ? I hope the latter...
Now let's try to reproduce our excavations and draw the circuit:
which, according to your description, might be equivalent to
which means the capacitor discharges over the 9 k##\Omega## in about 70 ns. [edit: 0.7 ##\mu##s]
I can't for the life of me understand how the pulse generator can come up with such a weird pulse shape, but other than that it looks like we have a bad case of impedance mismatching with ringing as a consequence.
Without further context in more detail it's hard to say anything sensible about this.
  • #37
Yes your interpretation is correct! Apologies I meant probe impedance is 900MΩ (scope impedance is 1MΩ).
What further context would you need?
From the posts I believe I have found out the energy within the capacitor at a specific time during the pulse. Now what I would like to understand is how to calculate the energy delivered by the pulse generator over 1 second.
  • #38
Brand name and type number of the pulse generator, so I can look up the specs :smile:
And what's on the scope if you remove the 80 pF capacitor :rolleyes: (if the probe can stand the pulse ...)
Freedom of religion, but I have hard time believing it...
Basically zero: whatever is pumped into the capacitor is almost immediately dissipated again by the 9 k##\Omega## :smile: .
But you could do ##(\int E(t)\,dt )/(\int \,dt )\ ##
IF (big IF) indeed the voltage over the capacitor is ##V(t) = \operatorname {sinc} {\pi t \over 75 \mu{\text s}} ## then ##E= {1\over 2} \int CV^2\, dt ## (over 1 pulse) times 4 pulses/s
  • #39
Great, thanks.
It is a bespoke made generator so no specs. Open circuit the pulse is the same shape but about 20% larger in both amplitude and width.
OK but even if it is dissipated into the 9kΩ there would have been a draw from the power supply surely?. So how do we calculate that energy coming from the power supply?
Isn't it times 250 pulses in a second? 250Hz, is a pulse every 4ms isn't it?
  • #40
Of course. I mixed up the 250 and the 4. So: yes.
Most peculiar. I know a capacitor causes lag in a signal. But I never expect lead ...
Or are the peaks shifted in time ?
  • #41
BvU said:
Of course. I mixed up the 250 and the 4. So: yes.Most peculiar. I know a capacitor causes lag in a signal. But I never expect lead ...
The peaks are actually shifted in time.
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 16 ·
